Mike8675309
I'm going to need a lot of help. Here are the questions I need answers to. Or tell me which ones I don't need to bother with.
With .030 pistons and 6.125 rods.
Finished Bore Size? Not necessary is it, as I'll determine that with the pistons in hand? Or do I put something there?
Stroke: 3.4" right?
Rod Length: 6.125" right?
Compression Distance: How would I calculate this?
Block Deck Height: Book says 9.2"
Piston to Deck: What would this number be?
Piston Type: Are we flat top with reliefs, or Dish?
Ring Groove Info: What is our specs for top, 2nd and oil?
Valve Pocket Info: Intake Depth, exhaust depth, valve angle, valve spacing, valve diameters?
Pin Lock Type: What pin lock type do you suggest?
Chamber Volume: Book shows 61.2cm^3 is that accurate?
Head Gasket #'s Do we need these? Do you know what the MLS or felpro numbers are?
Angle Cut Degree or Amount of Cut?
Rod Info: What are the small end and thickness above the pin for common 351 rods?
skirt shape: What shape are we going to want for ours?
I guess that's about it.
money is sent.
Stroke: 3.4" right?
money is sent.
