Thread: Headgaskets
    Sep 2005
    Calgary,Alberta
    18
    Question Headgaskets
    I am in the process of changing head gaskets on my 94 SC and bought the fel-pro kit which contains MLS gaskets.You said that you should not use these unless the block is milled.Does fel-pro make two different headgaskets for the SC(MLS and standard).If so than maybe I can return the MLS.I assumed fel-pro only made one gasket type for the SC.
    Mar 2003
    Niagara NY
    2,535
    Fel-Pro makes both kits for the SC. The composite ones are what most people use.
    May 2003
    Robinson, Pennsylvania
    1,122
    i just bought 2 felpro gaskets about 20 bucks a piece and intake gasket about 36 bucks
  1. Smaller Pully and Headgaskets
    By lpfan4life85 in forum Technical Forum
    Last Post: 05-15-2005, 11:56 AM
  2. Replaced Headgaskets, STILL WHITE SMOKE!!!!
    By 89xr7man in forum Technical Forum
    Last Post: 06-27-2004, 03:16 AM
  3. Blown Headgaskets.... Maybe?
    By 6pak2go in forum Technical Forum
    Last Post: 10-24-2003, 08:10 PM
  4. Done With New Headgasket's!
    By white90sc in forum Technical Forum
    Last Post: 02-20-2003, 02:53 AM
