Results 1 to 10 of 10
Thread: someone explain this please!
    Jul 2005
    134
    OK.....this might sound stupid, but here it goes anyway. My car makes 14lbs of boost. I have a custom blower outlet and I use a piece of blue silicone turbo hose to connect it with the stock "supercharged" tube. Both the blower outlet and the "supercharged" tube have quarter inch weld all the way around them to help prevent the silicone hose from sliding off, and I am using T-bolt clamps. You know what..........it still blows off every once and a while...............Now, If I were to go out in my garage and try to use my blowgun with only 14psi in my air compressor there wouldn't be enough force to blow a darn maple leaf off the hood of my car. Why is there such a big difference if both are 14psi.
    Aug 2005
    126
    Smaller volume?
    Jul 2005
    134
    With all do respect, that doesn't sound right to me. If that were the case 14psi in a 5 gallon air compressor would be greater that 14psi in a 30 gallon compresser. I just don't get it.
    Jan 2005
    SANFORD, FLORIDA
    73
    14 PSI - pounds per square inch. a 3" dia. tube has an area of about 7" at 14 psi is 100 lbs of seperation force. 14 PSI in an air hose at 1/4" dia. would be less than a pound of force. Thats if I remember physics class from 40 years ago. Catch you later, Bob.
    BLOODYBOBBER
    WHITE 89 SC AOD REMOVED SILENCER, K&N PANEL, C&L 76MM, MP RAISED TOP, IC FAN, MAGNECOR WIRES, COMP. LTD. HEADLIGHT HARNESS, 225 60 MICHILEN PILOTS -COMING SOON- Texas T-Birds ported manifolds, 2 1/4 DOWN TUBES, MAGNAFLOW RESONATOR, VES EXHAUST DUMP, BBK 75MM TB, S-TRIM BLOWER, MP INTAKE PLENUM, DOUBLE IC, 42' INJECTORS, 255LPH PUMP, 10% OVERDRIVE CRANK PULLEY, BHG BALANCER, PERFORMANCE CAM
    Jul 2005
    134
    Quote Originally Posted by bloodybobber
    ohhhh.......ok.........i see now
    I guess I shouldn't ask questions that I won't understand the answer, but thanks for trying to clear that up for me
    Jul 2005
    134
    ok....now that I thought about it more, I guess that does make sense.........It would be like drilling a pinhole in an oxygen tank or knocking the nozzle off with a hammer. One way would make a leak, the other would make a missle. Am I thinking correctly now?
    Jul 2004
    Salt Lake City, Utah
    1,521
    Looking at it from another angle, assuming that a fire hose and a garden hose have the same water pressure, which would you prefer to stand in front of?
    Jan 2003
    Columbia, SC
    3,468
    Quote Originally Posted by speedfreak
    You do realize that the location you note for your silicone hose is not always under pressure son't you? Is that silicone connecting hose rated for both pressure and vacumn? Not all hose is since it is actually "harder" to make a hose not collapse rather than not expand. It could be collapsing partially when you close the throttle and contributing to the hose working itself free from the clamps.
    Apr 2005
    BC, Canada
    586
    One of your gauge's might not be accurate?
    Jul 2005
    134
    Quote Originally Posted by Duffy Floyd
    I think that you are dead on with that. If you watch the hose when you first start the car, you can see it suck in a little bit between the clamps. I got the hose through my work (trucking company), and now have been told that the diesel motors that the hose is designed for do not have the vaccum of a gasoline engine, so that would explain it.
    My brother owns a company that specializes in water blasting, vac trucks, water boring, etc., he pretty much explained it to me like this........If somebody dumped a gallon of water on your head, it would pizz you off. If somebody dumped a 55 gallon drum of water on your head, it would knock you on your butt. The water is hitting you with the same pressure either way, there is just a much greater volume with the 55 gallon drum.
    .................ok, now I see what a stupid question I was asking you all, just common sense.
  1. The last shoot out??? Explain PLEASE????
    By pro street rich in forum Non Technical Forum
    Last Post: 09-22-2005, 08:56 PM
  2. Explain the reaction time to me please...
    By sizemoremk in forum Super Coupe Club of the Southeast
    Last Post: 09-18-2005, 04:48 PM
  3. Explain how a flipchip works.
    By Joey OKC in forum Non Technical Forum
    Last Post: 03-07-2003, 04:39 AM
  4. Somebody Please Explain Cams to me!!!
    By DV8ER SC in forum Super Coupe Club of Ontario
    Last Post: 02-11-2002, 03:58 PM
