Thread: EEC Tuner Error Message
    Aug 2002
    3,669
    Hello,
    Chip Version: 5.1
    EEC Computer: X1A2
    EEC Tuner Software Version: 2.08
    Problem: When attempting to 'Retrieve Modification' I receive this exact
    error.
    "Exception
    Base Modification Checksum Mismatch Error
    To check to make sure my connection is OK I can download all.eec and
    retrieve modification all.eec with no problem. It is when I attempt to
    load any other program; then retrieve it is when I receive the error.
    When connecting it to my car it will not start. Any help please?
    New Jersey
    1,335
    What are you using it on...
    That does not sound like a correct processor code.
    I do know that the 92-93 SC's won't accept the version 5.2 tuner. Could be a problem with that.
    I suggest that you change the checksum value to "0" which turns the check engine function off. Then try it again.
    Are you modifying a already programmed tuner or are you new to this???
    Does the other downloads work???
    Try the following:
    Go into the processor code you have.
    Type"ALL (Hit return) END"
    This will clear the tuner and see if you get that back on "retrieve Modifications"
    Don
    Aug 2002
    3,669
    Yes, I can download all.eec without a problem. I am attempting to download a Dave Dalke tune into it again. It used to work just fine until I took it to a place to get it 'tuned'. Now it does not work. He ~~~~ed it up good. I will attempt to do what you explained. Thanks
  2. EEC tuner and .bin files
    By supercatxr7 in forum Technical Forum
    Last Post: 08-04-2005, 11:13 PM
  3. EEC Tuner cut-out/CHECK ENGINE LIGHT
    By Kevin Keenan in forum Technical Forum
    Last Post: 06-24-2004, 06:10 PM
  4. EEC Tuner durablity ?'s...
    By ChaseTruck754 in forum Technical Forum
    Last Post: 02-10-2003, 06:47 PM
  5. EEC Tuner Installed!!!
    By SeanMatteson in forum Super Coupe Club of Ontario
    Last Post: 01-10-2003, 12:09 AM
