Results 1 to 10 of 10
Thread: Car leaks Oil only when shut off!
    Aug 2002
    Maryland
    199
    What would cause a vehicle to do this? It only leaks oil when the vehicle is shut off. Could it be an ATF leak that spins with torque converter and then leaks when not spinning"? It seems to be motor oil and it is low on oil when checked. Any ideas??
    Thanks
    Oct 2004
    Charlotte, NC
    8,159
    It could be a valve cover gasket.
    Is it leaking alot of oil or just a drip here and there?
    Aug 2002
    Maryland
    199
    alot
    It is leaking quite substantially...like 1/4 of a quart after 2-3 shut offs...so in a given day I would need to add about a quart...
    Aug 2005
    Central Arkansas
    920
    It probably has less to do with it being running or not and more to do with how warm the engine is. Things swell with heat and sometimes seal better. This is also very true in the aircraft world. You can try to tighten your valve cover gaskets down a bit more as they are rubber compound. Just dont go too far or they will leak worse.
    Oct 2004
    Charlotte, NC
    8,159
    Can you tell where the general area the leak is coming from......
    Front or back of the motor would probably be main seals....
    Rear corners would probably be valve covers.....
    Aug 2002
    Maryland
    199
    leak
    Nope...No leaking at or around the valve covers...the tranny/rear main area seem to be the culprit area. I took out tranny...rear main looks fine, no oil reserviors and no spray! I am lost...
    Aug 2005
    Central Arkansas
    920
    Get the oil dye kit from a parts house and run it for a little. the dye with black light will make it obvious where its coming from.
    Jan 2003
    California city, CA.
    828
    Wink
    well same here...I found my oil filter dripping after shutdown...next morning a lot too....1/2 a turn on the filter fixed that!!! was a mess under there too, I have maped leaks on my birds & I do this in the morning cool, pour gas over my
    suspect areas & rinse off the oils, push the car back clean up hot soapy water
    (dish soap like dawn) let dry & go drive & watch where it runs from. works for me.
    Matt
    Aug 2002
    Maryland
    199
    filter
    Man, how I wish it was my oil filter...that would be easy! No luck here, no direction...O well...Time for a new Honda...yes, I said HONDA and it gets 40MPG at 140HP.
    Aug 2005
    Central Arkansas
    920
    Dont let a simple thing like an oil leak drive you to a Honda All those miles per gallon still arent worth the cool points to me.
  1. Car doesnt shut off completely....HELP!
    By Dahoopd in forum Technical Forum
    Last Post: 08-20-2005, 03:43 PM
  2. Some Oil Questions (burning or losing)
    By al35thsc in forum Technical Forum
    Last Post: 09-21-2002, 03:33 PM
