Results 1 to 5 of 5
Thread: fuel pressure qusetion
    Apr 2003
    North Port FL
    1,386
    I have an external fuel pressure gauge and 60lb injectors, how much pressure should it read with only the key on? Thanks.
    Aug 2002
    Toronto
    1,745
    Key on engine off 35-45 psi.
    Engine running vacuum hose attached to regulator 30-45 psi
    " " detached 40-50 psi
    The hold pressure at schrader valve engine off should be 30-40 psi
    This is what i have from the board.
    Apr 2003
    North Port FL
    1,386
    Thanks 92strokedbird
    Aug 2002
    Toronto
    1,745
    You are welcome Jake!
    Quote Originally Posted by Jake
    Key on engine off, line primed, stock fuel pressure regulator, 40 psi +/- 1 psi. If you have an adjustable regulator, set the pressure static at 43.5 psi.
    Paul
  1. TCCOA TV Cable Adjustment
    By duanemyhre in forum Technical Forum
    Last Post: 02-01-2012, 11:55 AM
  2. Fuel pressure vs. Injector flow rate
    By Slysc in forum Technical Forum
    Last Post: 06-21-2005, 10:47 PM
  3. Correct fuel pressure?
    By blue94sc in forum Technical Forum
    Last Post: 03-24-2005, 03:03 AM
  4. Fuel Pressure Question.
    By Ryan A Harris in forum Technical Forum
    Last Post: 10-22-2003, 10:28 AM
