Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 42
Thread: new best et's......today
  1. #16
    Jan 2004
    Outside KC MO
    5,791
    Quote Originally Posted by midnitethunder
    ken shift it manual and u will hit around 100 u know the 1 to D back to 1 back into drive
    Thats actually pretty rough on the tranny.
    Chris
  2. #17
    Orem, UT
    5,902
    His problem sounds like with the shifter in D its going into overdrive. Mine did that too with the transgo. With my lentech, D is now 2nd gear and OD is 3rd and OD.
  3. #18
    Aug 2002
    North Georgia
    766
    interesting that its still going to overdrive with it "locked out" on the shifter. Mine holds 3rd gear while the yellow light is on (90+) and not shift into o/d until i shift it up to OD. Was thinkin about getting a shiftkit but if it does that, no thanks..ill just wait for a VB.
  4. #19
    Jan 2004
    Outside KC MO
    5,791
    Hmmmm...you would think that you could put a selonoid in there and have it activated by a button....hmmmmm....
    Chris
  5. #20
    Philly
    2,427
    My car is doing what Scott said. I am not a big fan of manually shifting an automatic tranny. My tranny shifts @5000 for each gear. I would not manually shift it unless I had to go to 6000.
    Later
    Ken
    1992 Thunderbird SC
    13.322 @ 102.81
    1993 Thunderbird SC 5spd..white
    2002 F350 SD Diesel (SC tow vehicle)
  6. #21
    Orem, UT
    5,902
    Mine with the lentech will shift at about 5000 rpms on the floor, but with these 3.27 gears it takes forever to pull to redline. I really want to put in some 3.73's but I don't know if I want to give up my highway mileage.
  7. #22
    Jun 2004
    68
    Quote Originally Posted by seawalkersee
    Chris
    it may be hard on the trans a little bit but thats how they made the valvebody so i did it in mine and my best time was a 13.43 at 103 with all bolt ons with 327 gears and street tires stock trans and b&m shiftkit so it cant hurt to try
  8. #23
    St. Louis, MO
    6,447
    Are you sure you didn't mean 3.73 gears? Can you list all of your mods please.
    Kurt K (e-mail)
    SCCoA Member #: 443
  9. #24
    Orem, UT
    5,902
    Whoa Kurt, your record might have been broken, although you didn't have access to these improved blowers back when you made your run.
  10. #25
    20,965
    Trans-Go shift kit on an AOD will very often cause a shift into OD (around 5000 rpms) when on the dyno or the track, even with the lever in D. Tightning the TV cable will help most times, but not always.
    Get the Lentech and be happy.
  11. #26
    Orem, UT
    5,902
    Quote Originally Posted by David Neibert
    Agreed.
  12. #27
    Jun 2004
    68
    Quote Originally Posted by Kurt K
    kurt all i had done to the car at the time was 87 mass 85 tbody 95 esm spec blower. top of the line more then likey better the mp3 blower top mpfmic chip stock long block stock trans b&m shiftkit aluminum drive shaft stock 327 gear with steet tires my time was 60 foot was 1.959 1/4 mile was 13.439 at 103.69 now if u want to see the car now come to carlisle nexted year i remember u my friend bought ur lentec trans pan off u. my car is completey differant now now it should run im hopeing 2 seconds faster from where it was since that last run i gutted the whole car and put about 12000 into it not saying what i did to much to list but it still has m90 on it and i hope to do the same thing kevin is going for and i will not post my times untill my goal time is made no nos 6>8
  13. #28
    Aug 2004
    123
    hey ken
    Allentown pa here did you ever get your car tuned yet? Those are good times my auto 93 with ported blower and stock tb and stock maf and my tune oh and stock gears went 14.7 at 92mph in the hot summer. oneqkgt@aol.com
  14. #29
    West Flamborough, Ontario, Canada
    5,429
    Way to go, Ken!!!
    ...Another one gets into the 13's!
    I had hoped to be there too, if I hadn't spun a bearing a few weeks back.
    I guess I need to get my butt in gear on a rebuild so that I can join our ranks first thing in the Spring.
    Cheers,
    Sean
  15. #30
    Philly
    2,427
    Quote Originally Posted by twoblownfords
    No, I have tuned my car yet. I was possbility looking into the spring. I am going to need it tuned for NOS also. I have a kit, but it is not fully installed. I am looking into 50-75 shot.
    I was going to e-mail and see what kinda deal we could set up, if you got enough people.
    Thanks
    Ken
    1992 Thunderbird SC
    13.322 @ 102.81
  1. Heard from Calvin today, it's bad, may need our help.
    By Vernon in forum Super Coupe Club of the Gulf Coast
    Last Post: 10-06-2005, 03:59 AM
  2. Heard from Calvin today, it's bad, may need our help.
    By Vernon in forum Non Technical Forum
    Last Post: 09-07-2005, 12:07 AM
  3. I hit the jackpot today :)
    By unclenick in forum Super Coupe Club of Florida
    Last Post: 09-05-2005, 01:15 AM
  4. Drove the car for the first time today! FINALLY!!!
    Last Post: 08-30-2003, 11:33 AM
  5. Bought some Iridium plugs today
    Last Post: 08-12-2002, 10:33 PM
