Obviously you'be never driven a ladder bar on the street!95badbirdsome said:kind of 5 link or ladder bar setup.
68COUGAR
68COUGAR said:Obviously you'be never driven a ladder bar on the street!
68COUGAR
David Neibert said:If you think your capable of building an entire car, then why don't you start with something easy like the rear suspension and drive.
Build a bolt on upgrade that includes everything needed to upgrade from the current 28 spline to 31 spline halfshafts on an MN12 and sell it for under $2,500.
If you can do that, then I will take all your talk about building a new SC seriously, and I'll even buy two kits from you.
If the price was right, Yes! I'd also buy a Factory Hot Rod Lincoln, IF the price was right!90SC BIG BLOCK said:I did build the car,WOULD YOU BUY IT?
68COUGAR said:If the price was right, Yes! I'd also buy a Factory Hot Rod Lincoln, IF the price was right!
68COUGAR
90SC BIG BLOCK said:There are already company's that will make a rear set up for you . And why would I start off small when even you would'nt swear to buy one of my cars ?Besides , I'm asking you ,if I did build the car,WOULD YOU BUY IT ??? My business plans aside. Even if I'm full of crap . WOULD YOU BUY A THUNDERBIRD IF WAS MADE ???
I seem to be short on enginuity these days....so I'll extend the same offer to you.
89SCK@t said:I would either use the cobra 32V Cobra motor, or the GT-40 motor. Those should be the ONLY motor options.
Stephen
quick35th said:Problem there is that the GT40 motor alone is $45k from Ford . But then it comes with everything, blower, assesorys, dry sump oiling system, computer and wiring, and flywheel+clutch.
I have my ideas on what the new Thunderbird should look like and perform but I'll keep them to myself for now.
Shane
1HUMINBIRD said:"I'd like to see a V6 that would stompass on the lame V8's rolling out of Detroit these days."
So, what is so lame about the V-8s rolling out of Detroit these days?
Scott Long said:I am going to go to Australia.
XR7 Dave said:I want to see an American made V6 powered hotrod. So far none of the manufacturers have dared to do it.
90blkbrd said:I finally get to correct Dave.
The Plymouth Prowler was a V6.
