Results 1 to 8 of 8
Thread: front pass. side upper control arm removal?
    Nov 2005
    11
    Question front pass. side upper control arm removal?
    did a search but could not find... what all do i need to take out to get the the back bolt on the fron pass. side upper control arm?..., i can see the front bolt under the intake tube but dont see how to get to the rear? help please~mike
    Jun 2003
    Oviedo, Fl.
    765
    Mike,
    What most folks do is remove the tab from the bolt head and use a 6 pt socket that fits. The tab is removed by prying on it with a large screw driver. Put a box or open end on the nut and remove the bolt. Reverse for re-assembly.
    Hope this helps you.
    Nov 2005
    11
    oh.. it all helps! thanks!.., there is some other stuff in the way before you get to the bolt do i just move it aside..? or is there anything else to disconect? thanks
    Jun 2003
    Oviedo, Fl.
    765
    Quote Originally Posted by 92scindallas
    Head of the bolt is located in the tire well next to the shock//spring assy. Nothing else to remove if you do it this way, though the nut might be a bit tricky to put back on. Nothing really difficult.
    Dallas, TX
    5,755
    Mike,
    Give me a call in about 1/2 hour and I'll see if I can give you some pointers. Here's 1 hint: Passengerside rear nut can be reached easily from underneath.
    Nov 2005
    11
    Quote Originally Posted by TbirdSCFan
    Mike,
    will do!.. thanks
    Apr 2005
    Nor Cal
    2,985
    I just did one of those on a 91 SC .. it sure was a pain to get off. We used a 18mm open end wrench and turned it a little at a time. It would almost be easier to take the front coilover shock out for more room.
    - Dan
    Aug 2005
    Central Arkansas
    920
    I did this once on a 96 cougar. I was fed up with the job and cut a small access door with a grinder to get at this bolt straight on. 10 minutes later, and I had the new upper arm in and was welding the access plate back on and the job was done. The plate was hidden behind the inner fender plastic. I dont recommend this really, but it worked for me. And as much as I dread this job on my 90SC, I will have all the same tools at my disposal.
  1. upper control arm
    By shawn in forum Technical Forum
    Last Post: 03-15-2020, 11:19 AM
  2. guys, help with upper control arm...please!
    By red Supercoupe in forum Technical Forum
    Last Post: 08-03-2017, 12:18 AM
  3. Continued ABS woes (and others)
  4. Upper/Lower Control Arm Bushings...
    By XsithX in forum Technical Forum
    Last Post: 08-02-2003, 12:40 AM
  5. Upper Control Arm replacement.
    Last Post: 06-06-2002, 07:18 PM
