Results 1 to 14 of 14
Thread: Over Heating Issue.
    Nov 2005
    Brooklin
    345
    Over Heating Issue.
    Hey Guys,
    My sc is overheating while i idle,gauge moves right into the 'red' area, i dont have actual temps.This is after 15 min idle,When im driving normal its fine.Any ideas?...Maybe i should wire up a control switch from the fan to the cockpit?...What would be the best way to do this,Should i install a relay?....Thanks Guys.
    Ed.
    Aug 2002
    Toronto
    1,745
    It could be the temp sensor located at the exit pipe to the rad at the top of the engine.It is a small sensor that sends the signal to the temp indicator in the dash.
    Nov 2005
    Brooklin
    345
    So until i can replace the sensor it will be fine right?.All it is doing is giving a false reading?...I have no other issues with cooling system.i just put a new w/pump in,changed the t/stat, no leaks anywhere,the coolant level is good with a 50/50 mix...Thoughts?
    Jan 2005
    Tampere/Finland
    913
    Are you sure your rad's fan is working properly?
    It's two speed fan, low speed/high speed. In my SC the low speed fan wasn't working so my temp was fine driving fast but when the speed was low it raised much. Check it!
    Dec 2005
    Dirty Jerz
    50
    Quote Originally Posted by Sampo
    I second this. Make sure the fan is turning on.
    Feb 2003
    Wichita, KS
    1,653
    Quote Originally Posted by Hill1513
    3rd, then check the fuses when you find the fan is not coming on. I ended up having to replace my puller motor.
    Oct 2004
    Charlotte, NC
    8,159
    Sounds like the IRCM isn't telling the fan to turn on.....
    Oct 2002
    Lansdowne, PA
    75
    From what has been said, I would say the easiest way to check this is to be very specific about when the gauge is giving a redline reading - if it just instantly goes straight to the red, from a normal reading, as soon as you stop driving and start idling, I'd say its the gauge or wiring. If it steadily increases, then it is more likely to be the fan. We need some more information to give a likely diagnosis.
    Jan 2005
    Tampere/Finland
    913
    Quote Originally Posted by Berserk
    You are right. Don't believe me. I don't know absolutely anything...
    But my car had that same problem and the IRCM wasn't working. The temp went up very fast when I stopped driving.
    If you start your car cold and then the temp will go to red immediately I say there's wrong with the wiring/temp sending unit/gauge.
    I can tell you if your fan isn't working properly the temp will go up very fast after driving 15 minutes!!!
    Nov 2004
    Brantford, ON
    5,383
    What ever the case may be, DO NOT DRIVE THE CAR UNTIL YOU KNOW WHY THE TEMP GAUGE IS GOING INTO THE RED!!!
    These motors run on the edge as it is, and if it is over heating, your gonna be out of a motor very shortly AND quite a few dollars...... if its not too late already. If you believe the statement of its just the sending unit to the gauge and it turns out NOT to be the problem..... well it sucks to be you....
    There's plenty of posts around here that tell you how to check if the IRCM is working properly, if the dual speeds on the fan is working properly etc. Investigate the problem and fix it right then you'll be a happy camper .
    Frit
    Oct 2002
    Lansdowne, PA
    75
    I didn't mean to suggest that you were wrong, I just didn't want to jump to a fan issue when to me it sounded more like the sending unit - I've had that issue, and if you get a good connection, it'll read fine, but sometimes just the lack of flex when you're not driving is enough to break the connection and give you a false reading.
    There are a lot of different things that could be wrong and I just wanted more information to give a better diagnosis.
    New Jersey
    1,335
    Here's .02!!!!
    I would do the following.....
    Run the car.
    Let it stand as you said to get thte temp to go up.
    Check to see if the fan is coming on.
    If no fan coming on.....replace IRCM (THEY DO GO BAD!!!)
    Check gauge sender..It's right near the thermostat housing. Let engine cool, remove and replace the sender. Worth to do anyway. You can test the sender by grounding the wire that goes to the sender. It should go straight to hot when grounded.
    These cars WILL go to hot when stopped when there is a cooling problem. You will damage your motor.
    You can also check on the fan by removing the harness plug to the coolant temp sensor (the computer one) at the passenger side of the blower. It's sort of angled to the side and sticks up out of the intake manifold.
    Remove the wire while the car is running and the fan should come on. If it does not, replace the sensor. If still not good, fan or IRCM is problem.
    Call me and I can walk you through it.
    Don
    (973) 277-4294
    New Jersey
    1,335
    Air Bubble!!!!
    Quote Originally Posted by tattoo
    After reading your post further, I noticed that you just replaced the water pump and filled coolant. Sounds like you have air trapped in the cooling system.
    Here's a fix.....
    With car cool....remove radiator cap. Start car. Let it run until warmed up. Coolant will start to over-flow the cap....do not worry....let it happen. Keep an eye on coolant level. When all air is gone, the coolant level will drop A LOT!!!! Add 50/50 mixture and all will be OK.!!!!!!
    Again, call me, I'll explain!!!
    Don
    Jan 2005
    Tampere/Finland
    913
    That's what I thought first!
    I didn't know you that you have just changed your coolant...
    I can tell you, I have experienced that also! No big deal to get those bubbles out.
    And Berserk, the most important thing is we can help asker anyway! As you said, there could be many reasons to overheating!
  1. Replies: 5
    Last Post: 10-04-2005, 01:54 PM
  2. moon roof issue
    By ThePikey in forum Technical Forum
    Last Post: 08-31-2005, 12:54 AM
  3. Engine Issue, Opinions or Options?
    By Evil Inside in forum Super Coupe Club of Florida
    Last Post: 01-09-2005, 10:07 PM
  4. Don't buy the November issue of MM&FF!
    By Bill McNeil in forum Super Coupe Club of Ontario
    Last Post: 09-25-2003, 07:37 PM
  5. Heating issue, is it the EEC
    By white94sc in forum Technical Forum
    Last Post: 09-16-2003, 06:40 AM
