Bird of Prey 94
How many bottles of fluid does it take to fill up the supercharger?
It's what keeps the supercharger alive!Spider said:what is supercharger fluid ?
Changed? Why would you need to change synthetic oil in a closed system? Checking every 30K yes, but change?91supacoop said:supercharger oil chould be checked/changed every 30K miles....i guess it depends on when the previous owner did it.
68COUGAR said:Dunno what Ford or GM charge for their oil or how many oz. you get.
I use BP 2380 Turbine Oil in my supercharger.
www.oil-store.com
Press AVAIATION button
Press BP TURBINE OIL button
$9.09 per qt.
Fill your SC 5 times with a qt.!!!!!
Turbo Oil 2380 - This polyol ester synthetic turbo oil meets the requirements of most corporate and commercial jet engines and accessories, as well as the requirements of industrial and marine lightweight gas turbines. It meets or exceeds the requirements of U.S. military specification MIL-L-23699F STD and U.K. Def Stan 91-101 (DERD 2497). BPTO 2380 is a superior 5-cSt jet engine oil due to its balanced combination of thermal and oxidation stability, load-carrying capacity, low volatility and low-temperature flow characteristics. Its outstanding performance, achieved through careful selection and balance of basestocks and additives, has made BPTO 2380 widely accepted in corporate/commercial aviation and industrial/marine applications. It is used by more that 325 commercial airlines worldwide.
68COUGAR
What? Jet airliners don't fly to Finland?Sampo said:I'm pretty sure I can't get Turbo Oil 2380 here in Finland.
68COUGAR said:What? Jet airliners don't fly to Finland?
Go to your closest airport & see if some mechanic will sell you a Liter of BP 2380. It's light purple.
68COUGAR
The benefit is that it's MUCH cheaper ($9.00/Qt.), than the stuff that Ford sells. It isn't necessarily a "benefit", but it also exceeds the specs. of the Ford/Eaton oil.bubbaflaat said:My question is what is the benifit to using this turbine oil? And how do you drain the old oil out of the supercharger.
besides the old fluid stinks to high heaven!
