Banana Bender
89 SC. I read a few of the posts on ABS problems on these, but I didn't see this specific symptom mentioned. Thanks ahead of time. You guys are always helpful.
Quote:
Originally Posted by rhodes588
Okay for some reason the ABS motor was drawing power all the time and drained my battery. Everytime i shut the car off, you can hear the ABS motor go on and it sounds like its vibrating rapidly. I pulled the fuse underneath the hood in the mean time. I need help ASAP!! Someone help!
Go to Autozone or Advance Auto, get a GP Sorenson Relay MR120. Should cost about $14 or so.
This is the ABS Pump Motor Relay. The only way an ABS pump can run with the car turned off is if this relay's contacts are stuck closed. Good thing you pulled the fuse because it would have burned up the pump motor in short order running that long.
Mine did the EXACT same thing 2 years ago. The relay is located on the passenger side firewall under the hood. I can't tell you which one it is right off but maybe someone else on this fine board can tell you exactly which one of the two or three relays in that location it is. You could also do a search for "ABS Relay" on this board.
