Results 1 to 7 of 7
Thread: Speedometers
    Fort Smith, Arkansas
    117
    Speedometers
    I'm sure this has been asked before but i can't check this forum as often as i like. Is the later style speedometer (140 MPH) a direct bolt in for the earlier style (120 MPH)? If not, what would be required to make it fit and work?
    2,998
    The 94-95 SC speedo (Ford part # F4SZ-17255-C) is a direct bolt in for the early models. I have one in my '89. Can't remember the exact price, but definately over the $100 mark.
    Some people have used the 160 MPH SHO speedo, but I believe it requires some mods and the green lighting does not exactly match.
    New Orleans, LA
    953
    I believe the 140 speedo is around 215USD or so at Ford.
    Try this link here:
    Car-Parts.com.............national wide auto savage search!
    Cheers,
    Calvin
    Sep 2002
    Stockton, CA
    530
    Hi there.. I am just curious... when you say direct Bolt in... are there any gears that need to be changed.. or can I take the old speedo out.. and plug this 140mph in and still have the correct reading... at any speed
    Karl
    Canton (Atlanta area) GA
    1,090
    Lightbulb
    Plug and Go
    Nov 2002
    Syracuse, NY
    504
    just hung up with ford cause i want one too, 213.00 for the 140 mph speedo.
    joe
    2,998
    No need to change gears as both the 120 and the 140 use the same gear (for the ring and pinion in use). The 140 justs reads higher on the scale!
    This is truly a bolt in swap!
