Results 1 to 12 of 12
Thread: What is this really?! ( A pic! )
    Jan 2005
    Tampere/Finland
    913
    Someone is selling this item by name power box and it's made by Powertech.
    What is this! A chip maybe!?!
    There is the Ford emblem on the top of it... How can there be a Ford emblem in an item made by Powertech?
    Sep 2004
    Indy
    5,623
    That's just a stock ECU, it isn't a chip.
    1994 SC
    4.5L Twin Turbo SVO
    Project GTFD
    Jan 2005
    Tampere/Finland
    913
    The seller tells that it's a power box!
    How can I get more power with ECU!?!
    Sep 2002
    4,857
    I think it's that black box on the end thats the power box.
    West Flamborough, Ontario, Canada
    5,429
    I'm with Jason on this one.
    I believe Powertech put out a chip that came in a module you sandwiched between the main plug going into the EEC, and the EEC itself. ...Like that black unit on the end where the main plug normally goes.
    Just get a chip and tune by Dave Dalke and be done with it!
    Cheers,
    Sean
    xThunderbirdSCx Guest
    Frikken ditto.....he is the best of the best when it comes to dyno tuning and chipping. People from as far as across the country from him ask for his work, and have never even met him!
    BTW, that "powerbox" looks like the one i had on my car before me and dave chipped it. It screws with your timing and thats about it. My car was running hella lean when it was on. It gave me no performance benefits whatsoever.
    E-mail XR7 Dave at mdkracing at alltel dot net he can hook you up with pricing and whatnot.
    Ask around, others will agree with me
    (EDIT: I also now see you are in Finland. You could still buy his chip, but you would have to tweek it yourself. Still, e-mail him and see what he can do)
    Jan 2005
    Tampere/Finland
    913
    Thanks guys!
    And quess what...I have emailed him so many times!
    I just thought I don't want to disturb him again asking what is this...
    But David if you see this...What information do you exactly need from the dyno when you are burning chip to my car?
    Apr 2005
    Buffalo City, WI
    1,050
    I can't speak 100% for Dave.... BUT I do recall him saying to do a "mailorder" chip he would need the dyno chart WITH A/F ratio at the very least. If you have a way you can provide MAF voltage compared to RPM I am sure that would help a bunch as well. If not make sure you give him a COMPLETE list of EVERYTHING done to the car and possible even brand names of parts used. Definately let him know what MAF, TB, Supercharger mods, supercharger overdrive, Stock or 180 degree thermostat, exhaust (stock or whatever).
    He may not need ALL this info, but the way I see it, I would rather send too much than not enough. Best bet of course is to contact him directly as he will tell you exactly what he HAS to have to do your chip/tune.
    Tracy
    Sep 2004
    Indy
    5,623
    Oh, I couldn't see the black box on the end, my bad.
    1994 SC
    4.5L Twin Turbo SVO
    Project GTFD
    May 2004
    Bmore
    3,228
    Whats the differance between a chip and a tune
    Quote Originally Posted by XR7inWI
    Tracy
    Can this be done without a dyno sheet or the car running. I know that sounds stupid, but I am in the process of getting the trans out to be sent out. While its out I will be putting 94/95 blower with 76mm MAF, 75mm TB and #42 injectors. I doubt the car will run with the changes to get to a dyno. Its 93 SC.
    Madison, Ohio
    17,574
    Quote Originally Posted by Sampo
    Thanks guys!
    Tracy is right. Mainly I need to know processor code, MAF, injectors, boost levels, internal engine and exhaust mods.
    Email me here.
    Madison, Ohio
    17,574
    Quote Originally Posted by Dahoopd
    If you get the correct MAF it will run fine. Let me know if you need anything for it.
    Email me here.
  1. 13 MN12's - satellite pic
    By tbird88 in forum Non Technical Forum
    Last Post: 11-30-2005, 03:09 PM
  2. I need a pic....
    By RedBirdSC in forum Technical Forum
    Last Post: 01-13-2005, 02:06 PM
  3. Replies: 4
    Last Post: 05-14-2004, 01:15 AM
  4. need a pic of windage tray installed on block
    By supercatxr7 in forum Technical Forum
    Last Post: 02-09-2003, 10:52 PM
  5. What is this part? Look at this pic.
    By biffteed in forum Technical Forum
    Last Post: 01-08-2003, 11:02 PM
