Results 1 to 2 of 2
Thread: Cooling fan fusible link
    SC
    35
    I while back I fried the cooling fan motor, and also the wire bundle that holds the fusible link for the fan motor. The fusible link connects to a much thicker guage wire. Because the fusible link wire burnt so bad, I have almost nothing left I can solder the fusible link to. I can get the solder to stick to the larger wire running back down to the engine. George D had a photo of how he re-did all the wires in the bundle before, but I can not find that post. Sorry this post is so vague. If anyone has ever replaced that fusible link you may know what wires and problems I am running into.. Can anyone help me out with how I should go about getting the fusible link soldered to the other wire..
    Thanks, Tom
    SC
    35
    I found the link/picture I was looking for.... It appears I need a bigger soldering gun to preform this work....
    If anyone has anything to add please post..
    Thanks Tom
  1. Fuseable Link for cooling fan
    By Brad94SC in forum Technical Forum
    Last Post: 12-09-2004, 01:25 PM
  2. Bacis cooling fan questions (pic and questions)
    By wwwtbirdforumcom in forum Technical Forum
    Last Post: 06-20-2003, 12:31 AM
  3. where is the fusible link for cooling fan?
    By cary Jackson in forum Technical Forum
    Last Post: 08-23-2002, 07:06 PM
