Converting to Late Model Master Cylinder
Phillio99
Is it possible to convert early model abs master cylinders to the late model which has the abs accumulator built in? I assume it should be able to drop in, any special tools or anything tricky i should know about?
Thanks,
Phil
You'll want to do some searching on the site, the topic has been brought up many times, it can be done.
The topic of switching to conventional brakes has been brought up many times, not switching master cylinders, how come you can't just wondering?
THanks,
Phil
THanks,
Phil
Technically you can do anything you want, but the two systems are totally different and so it is not going to be practical.
