Results 1 to 2 of 2
Thread: 94 sc
    Jan 2006
    michigan
    278
    94 sc
    i am buying a 94 but it has one hell of a miss to her. the guy said that it has blown hg but i dont think so it has none of the sign i have ever encountered. any help would be great.
    Nov 2005
    El Paso, TX
    192
    On a cold engine pull the radiator cap, check the coolant for carbon contamination, top it off, see if when you start it if forces coolant out of it.
    You can also do a power balance test. Pull on plug wire at a time, starting and shutting the car off before each. See which one(s) effect the idle the least(a good tachometer helps here). Now you can identify the cylinders which are having issues and check the plugs.
