Results 1 to 7 of 7
Thread: #14 and #17 Wires
    Plymouth, MI
    116
    #14 and #17 Wires
    Hey guys where are these wires and I know low fan just open #14 and to have a high Fan #17 must be grounded. Just need to know where these two are! Thanks
    New York
    174
    they are located behind the right headlight on the ircm. the little black box there. just read the wire numbers off the box.
    Muskegon, Michigan
    207
    not really
    Really all you have to do is cut the 14 or 17 wires i did'nt ground them at all.
    -Jerry-
    Vernon, BC
    1,929
    Umm yes you do.
    If you want low speed to run, cut 14 wire
    If you want high speed to run, ground the 17
    Simply cutting the 17 wire just ~~~~s you, because then you will never have a high speed fan
    New York
    174
    correct
    Illinois
    1,744
    Don't forget
    Remember it is still possible for the high speed winding to engage when you have low switched, and vice versa. If the computer tries to switch on one coil when the other is engaged, they will oppose each other's force and cause the motor to overheat. This has resulted in damage to the motor, connections, and even the fuse box in the experience of other ppl.
    The Great unwhite North
    985
    I don't have a electic fan, but i've played with electric motors before and agree with what digitalchaos..
    if your gonna be doing this kinda thing.. I would seriously surgest switching relays (ones with 87 and 87A on them) and wire it in so that if your manual over riding one speed, the other is automatic shut off and can't be used... it's not that hard to do, and it will save your ~~~ in the long run...
    Peace,
    Kevin
