Mike Puckett
One of of my SC's won't crank even though it's got a new starter from NAPA, solenoid on the fenderwell, and a new battery. The question is, where does the other end of the little black wire that activates the solenoid on the starter terminate. My electrical diagram doesn't show that wire, only the big wire for the main starter 12 volts. Jumping across the 2 big main terminals on the fenderwell solenoid won't cause it to crank either so it must mean that there is no voltage on the small wire. I can't check it because my arms aren't long enough to turn the key and lay under the car and check the voltage at the same time.
