Page 1 of 22 1234511 ... LastLast
Results 1 to 15 of 319
Thread: My Turbo Build up - WITH DYNO VIDEO!!!
    Aug 2002
    Prior Lake, MN
    1,302
    As some of you know myself and two other friends are building a turbo set-up and i am trying to document it, so i will start a new thread, the other one was just to see if anyone was interested, and apparently some of you are which is great, so here are just a few mroe pics of what we accomplished tonight also here is the link to the previous post i had which also has pictures.
    http://www.sccoa.com/forums/showthread.php?t=73096
    if anyone has tips ideas or questions id love to hear em...project is looking to be done by the end of this month hopefully.
    Nov 2005
    Marysville, Washington
    778
    the images quality on those pictures is extremely bad i think you might have uploaded the wrong set of pictures
    St. Louis, MO
    6,427
    Quote Originally Posted by Spider
    That may be, but they show more than enough detail to get the idea.
    Still looks cool though.
    Kurt K (e-mail)
    SCCoA Member #: 443
    NYC
    17,431
    Shrink pictures down a bit an dgood luck!...Id love to hear from ya once its running
    Zionsville PA
    448
    I can help with a base tune.
    20,948
    Keith,
    Since your setting up the MAF before the turbo (draw thru), you will need to install a bypass valve and route that air back to the pipe between the turbo inlet and MAF. If you use a BOV you will be dumping metered air to atmosphere causing a temporary rich condition everytime the BOV opens.
    So far what you've done looks good.
    Aug 2002
    Prior Lake, MN
    1,302
    Quote Originally Posted by BKB
    thanks, i currently have the mn12 performance tuner.
    David,
    i currently have a BOV, would i be able to still use this or how could i make it work?
    20,948
    Quote Originally Posted by aplvlydrtybird
    David,
    You could make it work by relocating the MAF to a position after the turbo (blow thru) and place the BOV before the MAF. That way any air that is exhausted doesn't matter, because it hasn't been metered by the MAF yet. That's how I have mine setup.
    The down side is, that in a blow thru pressurised configuration, the MAF doesn't have as much range and will peg sooner than in a draw thru. At the power level your going for it's not a problem.
    NYC
    17,431
    Or you can get a maf made especially from blow through type configurations
    Aug 2002
    Corpus Christi,TX
    547
    Quote Originally Posted by David Neibert
    Yeah, this is the conventional wisdom over on the Turbo Regal boards too. However, a friend killed a turbo in short order by closing the throttle too quick when he first got the car. He wanted to install a BOV but everyone claimed it had to be done as a bypass. Well he installed it as a BOV and guess what? It made no difference to how the car ran when you snapped the throttle closed on boost. Seems that GM put a little subroutine in their program called Deceleration Fuel Cut-off (DFCO) which shuts the injectors off when the throttle is closed when the engine is off idle and there is vehicle speed. I wouldn't be a bit surprised to find that Ford did something similar by another name.
    edit: at the same time we've learned to roll out of the throttle, instead of just dropping it like you would a N/A car, so a BOV isn't as important as we thought early on.
    20,948
    Quote Originally Posted by Parker Dean
    So how did he kill the turbo if he had the BOV installed correctly ?
    Aug 2002
    Prior Lake, MN
    1,302
    ok heres two scenarios...
    1. i leave the maf where it sits and still use the bov right after the intercooler before it hits the TB, what can go wrong.
    2. I put the maf right before the throttle body, where do i put the bov right after the air passes through the intercooler on the tube. is that where it goes. also how does this affect tuning??? any different than having the way i had it before???
    NYC
    17,431
    a bov ISNT AS IMPORTANT ON AN AUTOMATIC CAR BUT FOR A 5 SPEED YOU DEFINATELY NEED ONE.
    You would need a MAF able to work with a blow through setup because as David had stated you may peg it to early. The Maf itself should have as much room as it can before the TB and before it turns into the IC as possable if used as a blow through.
    Aug 2002
    Prior Lake, MN
    1,302
    so what would you suggest i do
    Aug 2002
    Corpus Christi,TX
    547
    Sorry, I must not have made it clear. The turbo got killed by backing out of the throttle too quick (excessive end play) within a couple weeks of getting the car. THEN he installed a BOV (THEN killed a tranny, THEN killed an engine, but that's another story ) Since his car has spent more down time than run time in the last year, we've been playing woth other peoples TR's that don't have BOV's and that's where we've learned to roll out of the throttle.
  2. Turbo Update #3
    By dirtybird91 in forum Non Technical Forum
    Last Post: 04-16-2005, 12:38 PM
  3. Turbo completion date....
    Last Post: 07-04-2004, 06:08 PM
  4. turbo setup supplier READ
    By turbospeed in forum Non Technical Forum
    Last Post: 12-15-2003, 04:15 PM
