Results 1 to 6 of 6
Thread: rear wheel bearing
    Jun 2005
    buffalo
    27
    rear wheel bearing
    Hey guys I just did a rotation on my SC and the right rear wheel is moving back and forth / side to side. I just wanted to know if its a wheel bearing or is it a whole hub assembly like the front wheels. Also what is the easist way to install them
    Grand Rapids, MI
    1,142
    There is a rear wheel bearing how-to write up in the SC Literature section I believe. It's not quite as simple as the front bearings since you need to have the old one pressed out and a new one pressed in. I would pull the wheel and see if you can isolate the movement to a specific part, but more than likely the bearing is bad. If it has gone too long then you may also need a new rear knuckle as well. Good luck.
    Joisey Jim Guest
    It's most likely the bearing; but with noticeable movement like you have you should be hearing it as you drive. Otherwise it could be bad bushings on one of the control arms. Hopefully you haven't damaged the hub or nuckle spindle and, a new bearing is only about $30 - but you'll need a local garage to press them in & out for you (say $10), plus a new lock nut.
    Jun 2005
    buffalo
    27
    thank you again
    Hey guys once again thank you for the help. The spindle was fine but the hub was seized to the bearing. I went down to the local U-PULL-IT Yard and removed the whole spindle off a 95 LX. It was a little cold here in buffalo but I got the job done.
    Sep 2003
    BUFFALO, NY
    532
    Quote Originally Posted by paully93sc
    HEY PAULLY- JUST TO LET YOU KNOW, IM HERE IN BUFFALO IF YOU NEED ANYTHING ELSE OR A HAND WITH ANYTHING.
    Jun 2003
    I75 GA/FLA line
    424
    just for future reference and im sure this is somewhere else on this site, if you get your old bearing out anyway. freeze the new bearing and stick the spindle in the oven for while. my last 3 or 4 have just fallen in doing this. before that i was ruining bearings trying to get them pressed in right. lotta work and the inner is 2 piece when the outer is one piece so its tricky
  1. Many Used SC Parts 1989 - 1995
    By sunny627 in forum Parts for Sale
    Last Post: 07-25-2013, 02:07 PM
  2. Continued ABS woes (and others)
  3. rear wheel dynos
    By rplaster in forum Technical Forum
    Last Post: 03-01-2003, 10:26 PM
  4. Rear wheel bearing and hup
    By Mez in forum Technical Forum
    Last Post: 11-11-2002, 04:56 AM
