Car2n
I need a little help guys. Could ya all look at the following pictures and the list below and tell me which vac ports mate up with which vac ports and the same thing with cooling lines. Let me know which places would not be used and should be capped/blocked off. Vac ports are shown alphibetically and cooling lines are shown numerically on the pics.
As far as I know, there is 2 places for cooling lines to go through the firewall (in & out) and 2 places for A/C lines to go through the firewall. (I won't be using the A/C)
A VAC PORT AT EGR VALVE
B VAC PORT AT EGR TUBE
C VAC PORT
D VAC PORT
E VAC PORT
F VAC PORT (NEEDS A SINGLE FITTING THAT GOES TO RETURN PLENUM?)
G VAC PORT AT BY-PASS VALVE
H VAC PORT (SMALL) ON FRONT SIDE OF INLET PLENUM
1 HOSE FITTING AT HARD LINE DRIVERS SIDE
2 HOSE FITTING AT HARD LINE PASSENGER SIDE
3 HOSE COMES FROM FITTING ON MANIFOLD AT SENSOR FITTING (TO FIREWALL?)
4 HOSE/HARDLINE RUNNING ALONG BACKSIDE OF ENGINE
5 HOSE/HARDLINE RUNNING ALONG BACKSIDE OF ENGINE
6 PVC VALVE PASSENGER SIDE VALVE COVER
C VAC PORT
D VAC PORT
E VAC PORT
