3/4 Tops For Sale!!!
ThunderRoad
get 5 or more 135.00 shipped lower 48 ...no exchange needed...check search sites for info on them...some have said cut et by 4/10ths:rolleyes:
Do you take paypal and how much shipped to Canada?
Tim You Have Been Around Londer Than Dirt!!
SO I GUESS YOU SHOULD GET A DEAL ...OK JUST LET OTHERS KNOW HOW MUCH YOU LIKE OR NOT ...AS I STAND BEHIND MY WORK ..OK;) FRED GROSS 324 DEVON RD FAIRLESS HILLS PA 19030 CHECK OR MO A CHECK WILL TAKE LONGER AS IT MUSTCLEAR FIRST???:confused:
I'll send ya a payment in a week or two...and during that time I will continue to promote your tops!!! :D Maybe then someothers will come aboard!
I guess I should have never sold the first one, huh! :rolleyes:
Thanks Fred!
-Tim
Sure You Can!!!!!!!
you are living example used for trying after market parts...maybe your can give a before and after results on it...;)
How do they compare to the magnun powers tops?
Or are these the magnum powers tops?
Do Search Under 3/4 & Fast Freddie
I HAVE RECIEVED CLAIM OF UP TO 4/10 OFF ON THE ET ,,,,,, THEY HAVE A 3/4 HIGHER CLEARANCE AS WELL AS 3/4 MORE OPENING IN THE THROAT ,,,,,MORE FLOW MORE POWER:cool: THE BEST MOD FOR THE COST:D
These tops are the same deal, just cosmetically different, since the bottom flange is about an inch thick, unlike the stock top. From owning one previously I can say that its worth the savings' (gains are comparable, between the two in other words).
Also, Fred. Money will be in the mail on Friday. Thanks again!
-Tim
Thanks For The Input
AS I SAID BEFORE...:p ALL YOU FOLKS ARE THE ONES THAT GOT ME STARTED...:D IT,S THE CHEAP MODS THAT MAKE THESE CARS RUN BETTER...:cool: I ONLY SHARE ALL THE TRICKS I LEARNED HERE...I TRY AND GIVE BACK WHAT HAS WORKED FOR ME.....:rolleyes:
Thanks Guys
i can,t believe all the folks buying these up....need to know if they is any more intrest ...as I will make up more, as I am running low and don,t want to disipoint anyone who want,s one ;) ..
here is your ups #
Thanks Fred!
-Tim
0301 0120 0009 7781 7983 should be there end of weekl:D
