Results 1 to 4 of 4
Thread: 4R70W trans question on Valve bodies
    Dacono, CO
    1,216
    Does anyone know, can I use the valve body out of a 1994 LX 4.6L in a 1994 SC?
    I'm helping a friend who has a fubared trans, and another friend has a 4.6L valve body with the updated and J-jod lready done.
    I know the cases are different as far as the bellhousing pattern goes, but just need to know if the valve bodies are the same.
    Also, can a Mark VIII tq converter be used with the 94-95 SC's?
    Thanks,
    Jeramie
    Aug 2004
    Batavia,OH
    2,019
    The valvebody is exactly the same no problems there. The markVIII converter can be used with a markVIII flexplate.
    Alan
    Dacono, CO
    1,216
    Cool! Thanks for the quick response..
    He has a Mark VIII tq converter and flexplate already, we just weren't sure if the crank pattern was the same. Good to hear it will work
    Does anyone know what a mk 8 converter will stall at on a stock SC?
    Aug 2004
    Batavia,OH
    2,019
    About 2300 on the brake. Realistically 2600
  2. Valve Bodies Debate: Art Carr VS. Lentech
    By Toms-SC in forum Non Technical Forum
    Last Post: 07-19-2005, 08:56 PM
  3. trans diff question
    By smokymance in forum Technical Forum
    Last Post: 02-27-2003, 03:00 PM
  4. Trans question
    By giddyup306 in forum Technical Forum
    Last Post: 12-09-2002, 01:46 AM
  5. trans question
    By ChrisMilltown in forum Technical Forum
    Last Post: 10-07-2002, 03:06 AM
