Need help
red92tbirdsc
My radiator recently blew when i was driving it. I replaced it with an all alluminum radiator. The car now just turns over but will not start. It has spark and fuel flow. I even shot starter fluid in it and it still will not start what could be a possible fault?
We're Going To Need More Info Than That... Did You Keep Driving It After The Radiator Blew (aka Overheat), Did You Remove Anything Else During The Radiator Install That You May Have Forgotten, Etc.....
The car stalled after the radiator blew and i got it towed home. Theres gas in it, everythings connected but still wont start.
Check your crank sensor. If coolant got on it, it could have damaged it.
When I Had My Car Towed, The Tow Truck Driver Set The Car Down Alittle Hard And Tripped The Fuel Pump Shut Off Switch. Its A Red Button In The Drivers Side Panel Of The Trunk. See If You Can Here The Fuel Pump Turning When You To The Key To The Run Position.
