Results 1 to 12 of 12
Thread: turn a base engine to sc
    Dec 2002
    Budapest, Hungary
    38
    Question turn a base engine to sc
    Hi,
    how hard to turn the base engine to a supercharged one?
    can it be at all?
    Feb 2004
    Outside Vancouver BC
    824
    I guess it is possible but you'd have to replace so many parts it would just be better off to either by a SC or an engine from a SC.
    Mar 2006
    Dayton, OHIO
    142
    on what engine are you installing it on? If it's a regular 3.8 with high compression, it won't work too good. that you have to replcace heads, bolts/studs - better, and front brackets, with more stuff. Not worth it...
    Dec 2002
    Budapest, Hungary
    38
    its a regular '92 3.8L. i just try to find a money saving way, because at here u shold pay a lot of fee if u want to change the engine...
    Blair, Nebraska
    3,257
    I suggest either swapping the engine/trans or getting a Vortech SC kit. If your on a budget and/or parts are hard to come by - you might just want to do the Vortech. If you've got some money to play with, find a good donor SC with a bad body where you can take all the parts from it - engine, trans, 8.8 rear end, some wiring harnesses, and anything else you come across you might decide you want.
    -Melon
    Oct 2002
    Lincoln, NE
    2,062
    Quote Originally Posted by Melon
    -Melon
    Andy, you might want to check where he's from...
    As for making an N/A 3.8 into a supercharged engine...Check out this link.
    http://www.sccoa.com/articles/everwonder.php
    It's here on this site and pretty much explains all the changes that were made for the SC engine. You'd have to pretty much do the same thing, (including getting a SC block to start as a base). I don't know what the cost is for installing a different engine, but it might actually be cheaper than trying to build one from scratch.
    xThunderbirdSCx Guest
    NOT worth it man. Just buy an SC. Even a modified one, Theyre a dime a dozen .
    Apr 2005
    Buffalo City, WI
    1,050
    Quote Originally Posted by xThunderbirdSCx
    Probably NOT a dime a dozen in Budapest, Hungary.
    Feb 2006
    1,964
    I would agree that they aren't common in Hungary.
    Dec 2002
    Budapest, Hungary
    38
    find a donor sc in here is harder than get a polar bear less than 30 '89-'97 thunderbird run at here, probably 30% is SC. so i should try to search in europa, but than i should a pay lot of tax, and fee... :/
    Dec 2002
    Budapest, Hungary
    38
    thx the link Sam, i saw the block is totaly diferent... so is not worth it
    SOONERS country
    147
    Wow, i thought SC parts were hard enough to find here!
    NRG, here is another forum for V6 T-Birds;
    you might see some other ideas you could use.
    http://forums.tccoa.com/forumdisplay.php?f=9
    Also V6Power might have some ideas;
    http://www.v6power.net/vb/index.php
    Good luck with your big beautiful American Thunderbird!
  1. Engine dies when I turn the steering wheel
    By Jim175 in forum Technical Forum
    Last Post: 11-10-2005, 05:03 PM
  2. Engine Swap, traumatic?
    Last Post: 01-17-2005, 04:33 AM
  3. Hypothetical question..'03 Cobra Engine swap into SC...
    By Mike Manzo in forum Technical Forum
    Last Post: 11-20-2002, 04:40 PM
