darkstar_one
Hey,
I removed my rear lower control arm to replace the bushings. How do you go about removing them? Do you press them out? How do you press em out? Do you require a special tool? Or should i just take em to the local machine shop to press them out?
Also, the toe compensator link bushings to the frame are worn out. It has too much play. I will be buying the AUTOZONE DURALAST replacement bushings for the lower control arm to frame bushings. As for the toe compensator link i guess i will just have to go with the MOOG one from ROCKAUTO.com since i dont believe autozone has them.
