Results 1 to 5 of 5
Thread: Strange problems, alternator maybe?
    Mar 2006
    Bristol, PA
    194
    Ok, so for the last few days, my battery light in the dash has been coming on. i didnt think much of this, because it goes off after a few minutes. Today, i noticed that when the window is up, and i push the up part of the switch, the battery light comes on.
    Today, i was driving home from a friends house, and things really started to go crazy. When i dropped her off, i noticed that the interior lights were very dim, thinking that it may be a battery or alternator prob, i didnt shut the car off. On the way home, the headlight seemed dim, and the dash lights started to dim. the battery light was still flickering on and off. I decided to turn off the cd player, so i took the faceplate off, and verified that the amp shut off. Then, the climate control display starts blinking, the firm ride light blinks, and so does the abs light, all at random. I turn the firm ride off, and i continue on my way. THen i notice when i put the turn signal on, the abs light blinks wit teh turn signal arrow. When i got closer to home, the HVAC started to come on and off randomly.
    Anyone experience any of these problems?
    Does it sound like an alternator problem?
    Battery?
    Any comments or suggestions are greatly appreciated!
    Thanks,
    -Nick
    Mar 2003
    Edmonton, Alberta Canada
    3,062
    Sounds like the alt. is pooched. The dimming lights are a good indicator.
    Mar 2003
    3,062
    If you take it to a local parts supplier they could probably test it for you.
    Mar 2006
    Bristol, PA
    194
    i think the autozone near me tests alts. it cant be too hard to pull, ill probably do that today
    Bristol, CT, USA
    1,121
    you can test it yourself, need 2 ppl, start your car, have a volt meter on the batt, and as you press the window switch, check the voltage if it drops below 13v, change the alternator..
  1. sc problems
    By PilotYFZ in forum Technical Forum
    Last Post: 08-30-2006, 07:30 PM
  2. Strange Problems
    By paul90 in forum Technical Forum
    Last Post: 01-30-2005, 11:35 AM
  3. Replies: 7
    Last Post: 10-02-2004, 01:02 AM
  4. Idleling problems, We added alot of HP to our SC
    By victor malvar in forum Super Coupe Club of Florida
    Last Post: 11-03-2003, 03:44 PM
  5. Electrical Problems: Car is DEAD! Help PLEASE
    By Tim Groth in forum Technical Forum
    Last Post: 06-21-2003, 10:02 PM
