NY90RedSC
I am putting my 1990 red Supercoupe up for sale. As it says in the header, this car is a 5 spd car. Below is a list of options/upgrades that have been done to the car:
For sale 1990 Ford Thunderbird S/C 5speed
Red with black leather int
No rust or rot (Florida car)
Some dings and a small dent(ln front fender)
3.8 l super charge engine (build 15psi boost)
175k miles
16" wheels with 99.5% tire left (alum spare)
4 wheel disc brakes
am/fm casset/cd premium sound with sub with imfo center(FM not working)
just add to replace the no working fm on car radio...
Power ant working
3.08 rear gears
White face gauges with duel gauge pod with water temp/volts/
Full leather inter with 8way seats and pull down rear seat in good shape(no rips or tairs)
Retractable seatbelts work
New aftermarket headlamps ... fog light work with sliver star blubs
ARC work great
New motor mounts
New front strut rod bushing front/back
New front brakes
Rear spoiler with led brake light
Has the sc in the front bumper
Replaced ABS brakes with vacuum system off a 93 t-bird (new back lines and clean brake fluid)
New engine steel pulleys all 3 of them
Battery relocated to rear in trunk useing 2g wire
Cold air intake with filter in lower bumper
180 thermostat
Windows work and door locks to also keypad works(but have to used keypad to disable alarm wont work with key)
ac and heat work ... ac convert to r134
oil is Mobil Synthetic 10w/30
Starts and idles great
No surface rust or rot on car
Looks ok for a 14year old car
Paint has some clear coat failure
Power sunroof
11" pusher fan monted in front of a/c but not wire up yet
Has black dash cover..dash has no rips or cracks had the sliding tray
tint windows 35% all around the back half of car
New Battery
New Ignition Lock & Key Cylinder
ISSUES WITH CAR:
2nd Gear Synchros will need attention eventually. Car does shift if you double clutch from 1st to 2nd. Downshifting is a tad harder with the synchros acting up. Clutch is OK (car is used every day)
Reverse lights do not work. I suspect it's the switch that mounts in the transmission. I have the switch, just haven't had time to swap it out.
Car needs emergency brake cables and also exhaust work. NYS Inspection expires this month and I am not going to sink the money into the car at this time. I would prefer to see this car go to someone who has the money and ambition to restore this car back to it's former glory. The car has a TON of potential and is still an excellent daily driver. I travel extensively and I can't justify putting the miles on this car and don't want to run it into the ground.
SERIOUS INQUIRIES ONLY PLEASE!!!!
I'm asking $2500 or best offer. This car does need to go though,and go SOON. I need to get a newer car as soon as possible and will be using the money from this car toward a newer car. I am also not interested in trades at this time. Cash only transaction please. This car is located in Upstate New York in the Capital District/ Albany Area. Serious inquiries for pics only as well.
This car is a great turn-kay Supercoupe. It runs 100% and will make someone a fantastic car. I would not hesitate to drive this car anywhere at anytime at the drop of a hat.
Thanks!!!
175k miles
4 wheel disc brakes
Power ant working
3.08 rear gears
ARC work great
New motor mounts
New front brakes
180 thermostat
Power sunroof
New Battery
ISSUES WITH CAR:
Thanks!!!
