Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: best way to soak up oil in street
    Dec 2005
    scrillicon valley, ca
    1,041
    so ive had this small oil leak and over time its left a huge slick in front of my house. ive since fixed the problem, and am now left with this huge ~~~ oil slick. how can i clean this up?
    degreaser and cat litter?
    this isnt the driveway its the black street with blacker oil. any help is useful and appreciated
    Canton (Atlanta area) GA
    1,090
    I use generic store-brand (the cheap stuff) unscented cat litter on my concrete driveway. It works fairly well. You could also probably just dump a bucket of sand on it if it is in the street.
    xThunderbirdSCx Guest
    did you know you can use old motor oil to fertilize your lawn?
    SW Michigan
    2,222
    and then try this
    If the kitty litter doesn't take up all the oil, Try some industrial degreaser & a very stiff push broom.
    68COUGAR
    May 2004
    Bmore
    3,228
    Quote Originally Posted by 68COUGAR
    68COUGAR
    I have found that after you soak the oil up with litter. You can take powdered laundry dtergent and a stiff bristle broom and get the rest up. It wont get rid of the stain.
    Degreaser may work but I have found it softens the black top and just makes it worse later. Maybe I used too much.
    Feb 2004
    Outside Vancouver BC
    824
    Quote Originally Posted by xThunderbirdSCx
    Hate to burst your bubble but that's 100% not true. Washing your car on your lawn will fertilize it. I seriously hope you don't pour oil on your lawn!!! 1L of oil can make 10m3 of soil contaminated. Who told you that?
    I wouldn't recommend drinking it either because it takes awful.
    Quote Originally Posted by Grims95SC
    no i dump it on the lawn by the gallons. oil is great for grass and antifreeze does wonders for killing weeds. Nettlesd showed me that trick
    Feb 2004
    824
    I really, really hope this is a joke.
    Dec 2005
    1,041
    cant be to sure
    ive had people tell me that using tranny fluid is good for the paint??? maybe back before clear coats.
    Aug 2005
    Central Arkansas
    921
    If its blacktop, its full of oil anyway, just get up the puddle with kitty litter and the rest will stay with the road.
    Oct 2002
    Cincinnati
    130
    Kitchen Flour work awesome
    Dec 2005
    1,041
    seriously?
    mixed with anything?
    i know people who say spray it down with water
    pour kitty litter,
    let it soak some more water and oil, let dry, let sweeper guy clean it monday.
    then go out with degreaser, and bucket water down, and scrub with wire brush.
    Mar 2006
    Bristol, PA
    194
    on my concrete driveway, i've had luck with Brakleen. Just the other day, it was warm and sunny out, i sprayed my stains with it, let it dry, sprayed, let dry, maybe 3-4 times. After that, i sprayed the stains, and rinsed with the hose. There was qutie a noticable difference. Im not sure if the same works for asphalt, but it may be worth a try. Also, my stains i think were more trans fliud than oil, im not sure if there is a difference when it comes to removal.
    -Nick
    Dec 2005
    1,041
    i shoudl have never
    had an oil leak. i bought the car without one, had new oil put in it, oil leak the next day. i took it to the place told them to recheck the filter, and the plug, but they insisted i had to replace the front seal. not unheard of, but i was reluctant. i then used some seafoam to clean the injectors, which casued a misfire i have had with this car for months, and cleared the crankcase of sludge. drained oil replaced it and no oil leak. amazing.
    love that seafoam stuff, my injectors would deprive my car of gas in the heat, cuz my car got hot. and it would stumble, and feel like a genuine misfire from a plug or wireset. wasnt the dis, plugs, wireset, or the coilpack. vaccum lines were good, and so is the tranny. whats left? a can of seafoam, and some praying. well im so happy so very happy that i even felt like cleaning my stains for my ~~~~~~~ neighbors!
    no more overheat, i use ice water 40 degrees below. mixed with water this stuff helped me stay cool in traffick and under great boost levels.
    anyways thanks for the info you guys, this site has helped me in so many ways.
  1. Race Dates 2006 and other events in SoCal!!!
    By BT Motorsports in forum Super Coupe Club of Southern California
    Last Post: 02-10-2007, 04:51 PM
  2. steps to change oil for men and women LOL LOL !!!
    By stephens89sc in forum Non Technical Forum
    Last Post: 12-20-2006, 08:56 PM
  3. engine oil cooler: is it needed??
    By 89cougar in forum Technical Forum
    Last Post: 09-13-2004, 08:54 PM
  4. Maintenance Schedule?
    By Flip in forum New SC Owner Forum
    Last Post: 08-31-2003, 07:36 PM
