Results 1 to 7 of 7
Thread: what are symptoms of clogged cats and cam and crank sensor failure
    Apr 2004
    48183
    3,934
    i need all cases of these going bad
    xThunderbirdSCx Guest
    Clogged cats would be unusually high boost and bad throttle response.
    Bad Crank sensor would be when you crank the engine, the upshift light stays on.
    Not sure on the cam sensor.
    Use the search function, bud.
    Joisey Jim Guest
    Can Sensor would be intermittent rough idle followed by either a fluctuating tach (early models) or a 214 CEL code.
    Nov 2005
    Oregon 97220
    1,018
    Question
    Quote Originally Posted by Joisey Jim
    How about a s---s---s---s---s---s---surge?
    It happened to me on the highway twice at 60-65mph.
    Its happened with 2 different MAFS/intakes.
    Weather was same both times.
    My theory is the rough idle and surging are because of the ecm/dis losing track of ignition timing......Am I right?
    My tach sometimes doesn't work, and the 6-try start thing happens like 3 times a week.....
    I'm waiting for my new CPS in the mail......
    paul
    Jul 2005
    Tracy, California, USA
    502
    So lets say its clogged cats... what is the remedy ?
    ur kidding right?
    I hear drain-o in your crank case helps clear out clogged cats
    The only remedy is to either punch them out, replace them with new high flow cats, or delete them all together.
    Dec 2005
    scrillicon valley, ca
    1,041
    if they are stockers get em out anyways
    so very restrictive. when mines madea rattle, i figured, why not go hi flow, and take that weak 90* bend out.
