I'd agree with Tom, 3.27 is what I would recommend for the max. gearing with a 5 speed SC. I have those in my 95, the car accelerates awesome in 5th now. First is a bit short, but not too bad. The 94 and 95 had a bit taller 1st gear ratio than 89-93, so it's not so steep when you do change rear gear ratios. If you're planning on putting a bunch more power in the car later, go with 3.08. If you plan on keeping it mild, the 3.27 works nice, and you don't loose any top speed, it just revs a bit higher in 5th (mine went 4600 rpm in 5th with 27.0" tall tires for 150.7 mph).
cheers
Ed Nicholson
SCCoO
