Results 1 to 6 of 6
Thread: what kind of RTV???
    Brantford, Ontario, Canada
    4,004
    Question what kind of RTV???
    What kind of RTV is used on the crank shaft, when installing a new harmonic balancer?
    Toronto, Canada
    3,809
    Ryan,
    I think Tom used copper RTV all around the oil pan, and on the front around the seal. Maybe Sean will recall better?
    West Flamborough, Ontario, Canada
    5,429
    The snout of the crankshaft is sealed in the timing cover via your front main seal. No RTV is necessary there. The oil pan is sealed to the bottom of the block and the timing cover by RTV from the factory, or by a cork gasket and RTV if Tom rebuilds the motor for you.
    Does that answer your question, Ryan, or did I misinterpret what you were asking for?
    Best regards,
    Sean
    Toronto, Ont, CANA-DUH
    2,002
    sghse
    Toronto, Canada
    3,809
    Sean,
    Mine was copper from Tom.
    Ryan,
    Answer = copper.
    Thorold, Ontario, Canada
    2,432
    yeah the copper stuff will work fine, the keyway needs RTV on it to prevent oil from coming out the keyway, thats what Tom told me! IS not likely to come out but it could so thats why we put RTV there.
