Results 1 to 5 of 5
Thread: Subject: Need Help Check Engine Light and Gas Fumes in Car 94 SC Tbird
    Jan 2004
    Brooklyn, NY
    113
    My check engine light is coming on, and I have been smelling gas fumes in the car as well. I have been using 89 octane gas for a while, after the pinging I realized I should go back to 91+ octane. Could I have a bad fuel vapor canister or purge regulator valve? I have not changed either device since I had the car. Can the fuel vapor canister or purge regulator valve be the reason why my check engine light comes on and off?
    Any advice is welcomed!
    Thanks,
    Bird of Prey 94
    Bird of Prey 94
    Mamaroneck, NY
    209
    First - pull codes. They can lead you in the right direction.
    Second - the gas smell - check to see if leaking at any fitting or at injector rail. Does the engine compartment smell of gas
    or just the interior? If it's just the interior and mostly when the car is running - check to see if gas line at top of gas tank is worn through and leaking. The line is a nylon material and can rub against the body, eventually wearing through. There was a recall on earlier cars to check and either install a shield over the line or replace the line. I replaced my line with a reinforced fuel line from BMW.
    Third - DON'T LIGHT UP ANY SMOKE - until yhou find it and repair. If you have to drive the car - make sure you keep window open some so you don't get overcome by fumes - I'd hate to see you wreck an SC!!!!
    Good Luck.
    Mark
    '95 SC 5spd
    Jul 2003
    Eastern (nee Western) PA
    4,993
    The evap system could be the problem. You should check the codes, that's what they're for.
    God bless!!!
    Former Birds:
    Apr 2005
    BC, Canada
    586
    running always rich will cause the check engine light to light.
    Aug 2004
    KSRQ
    5,220
    I have been following this thread because I have a similar problem in my 95. Gas fumes seem to be coming through the ventilation system though and are strongest when the car is first started up. No CEL codes to check though.
    Does this sound like the same problem??
    Ira
  2. holy crap. Jet engine VW BUG!!!
    By SCandelous95 in forum Non Technical Forum
    Last Post: 06-27-2006, 09:49 PM
  3. car wants to stall + check engine light
    By LikeNew92 in forum Technical Forum
    Last Post: 03-24-2005, 08:38 PM
  4. Check Engine Light
    By VPICHE in forum Technical Forum
    Last Post: 12-02-2003, 07:21 PM
