Results 1 to 15 of 20
Thread: Horrible problem
    Mar 2004
    Clarksville, TN
    331
    Horrible problem
    hey guys. well, this is my sc nightmare number 3. just got my exhaust put in my 5spd today and while i have the car running it shuts off and wont start up. revs fine while its running but then just dies. if you wait a long time it starts back up fine, then does it again. things we have done (its me and paul meadows working on this thing..)
    1. swapped computers
    2. swapped dis modules
    3. swapped coil packs
    4. swapped crank sensor
    5. put gas in car (had a mustang that did this when it ran out of gas. my gauge doesnt work)
    6. jumped fuel pump relay in case that relay was bad
    7. checked ignition switch
    8. tried it with mafs disconnected
    9. confirmed lack of spark by disconnecting a plug wire at the coil pack and looking for spark. it sparked once, started, ran, then the spark went out.
    the only thing we didnt swap was the ircm relay box. we strongly suspect the exhaust shop didnt disconnect the battery on the car, then welded on the exhaust while it was installed. this could potentially damage critical ignition components. any takers? i'll post an update when i figure this mess out.
    Southern California
    916
    Did you check for any trouble codes?
    Here's a little thing on checking the diss on a no start problem, maybe you can use it.
    I don't remember them disconnecting my battery when i had my FloMaster stuff put on. And i didn't have any problems.
    Tony
    Attached Files Attached Files
    Mar 2004
    Clarksville, TN
    331
    yea, that would probably have been another bit of useful info. the cel never came on. and im talking about a couple of hours of tinkering.
    Mar 2004
    Clarksville, TN
    331
    well, swapping out the ircm didnt help. i think i have a fried computer. something in there is getting hot to the point of shutting down, which would explain the car running fine if you wait a few minutes. it just wont stay running. im going to try a swap here in a bit and see if that helps..
    Jun 2005
    Tampa, FL
    156
    Have you checked the cam sensor? Usually lack of spark is caused by a bad cam sensor.
    Sep 2003
    P-Town, MN
    2,511
    Mine did the same thing when the cam sensor failed. It would start if I let it sit for 20+ mins. But would not start if I warmed up the car, shut it off and then tried to restart it.
    It's only impossible until we do it.
    22-year SC owner - '93 SC AOD (non-locking TC). Same car, same original paint!
    Current setup: 12.550 @ 111.09, 1.917 60ft, no bottle.
    Jun 2005
    buffalo
    27
    I had the same problem
    When I had a problem like that it was when i put a new tranny in the car and both o2 sensor wires were broke. I guess It happened when I took the exhaust off. The bird would run for a few mins then shut off. I would check to see if the shop maybe disconnected them.
    Mar 2004
    Clarksville, TN
    331
    wouldnt the o2's set off a cel? its worth a try anyways. i'll take a look under there in a bit. im going to try the ignition switch, and if that doesnt work, i guess im shelling the money over for a reman on my computer.. i still have to pull it later and hopefully someone around here has a compatible one that i can get for cheaper than my other options.. i did a cam sensor swap just now and that sure didnt work..
    Sep 2003
    P-Town, MN
    2,511
    Good luck. Tracking down this stuff can really suck.
    Mar 2006
    Dayton, OHIO
    142
    Quote Originally Posted by specops_SC View Post
    Did you replace cam sensor, usually they go out if never been replaced.
    also, when you cranking it and it won't start. Does tach move?
    Mine was running ruff and was in 17.9 sec first I tred then I was running 15.8 after cam sensor was replaced and motor mounts, currently 14.1 - STOCK
    Mar 2004
    Clarksville, TN
    331
    Angry after 3 days i find out that...
    hey sc power, yea, i tried cam sensor swaps. the tach jumps around a little while starting and the upshift light goes out. sometimes it wont come on and the car still wont start, but usually right after it dies it'll stay on during cranking. also, the ignition switch swap did nothing to help the problem. we hooked up a voltmeter to the pip input wire right at the computer to verify it was receiving a signal which it did right to the very end. it was in the 6.0-6.2 volts range. wire 56 dark blue on the pcm module. so, this along with the 211 (pip signal loss) code that we got has led me to believe my computer is fried. going to try to get one here and if not, guess im spending 270 bucks on a reman.. thanks to everyone for their input and help.
    Moses
    Sep 2003
    P-Town, MN
    2,511
    Moses
    Did you check the EEC fuse in the box up front in engine bay?
    Mar 2004
    Clarksville, TN
    331
    actually, the sc model doesnt have a fuse for the eec in the fuse box in the engine bay. the eec works fine up to a certain point, then it just kills the car. with a koeo test, the system passes fine. however, everything is getting to the computer just fine, which leads to the ignition circuits in the computer being mest up somehow. it doesnt quite make sense, but its the last thing left..
    Sep 2003
    P-Town, MN
    2,511
    You sure about that? My '93 SC does. It might be labeled something else, but it is for the EEC. Trying to draw from memory, I think it is the second to the last or the last fuse. I'll look when I get home.
    Sep 2003
    P-Town, MN
    2,511
    Well, it most likely isn't the EEC fuse since the car will restart eventually. But, for anyone reading this for info, there is an EEC fuse in the front high current fuse box. It is fuse G and is the fourth to the last fuse on the RH side of the front row. See pic.
  1. Stock CD player/Radio problem, PLEASE HELP!!!
    By dbledown00 in forum Technical Forum
    Last Post: 06-22-2013, 12:39 AM
  2. HELP with misfire problem
    By trench in forum Technical Forum
    Last Post: 09-23-2007, 11:41 PM
  3. Head Light problem, need help A.S.A.P. Please
    By SC90_Pete in forum Technical Forum
    Last Post: 01-10-2005, 06:11 PM
  4. AOD Shifting Problem...
    By tbirdman in forum Technical Forum
    Last Post: 08-08-2003, 09:43 PM
  5. New or Still Old Problem
    By T1Bird in forum Super Coupe Club of Ontario
    Last Post: 06-30-2003, 10:09 AM
