Results 1 to 11 of 11
Thread: Roots blowers and engine stress
    Dec 2005
    Wisconsin
    13
    I've been running my m112/v6 since July. I've put over 8k miles on it to date as my daily driver. In the summer I was getting max boost of between 5-6psi with my pulley config. Lately I'm getting 7psi with the cooler/drier air. All has been fine at this level. But I'm wondering, how strong is the crank snout on these 3.8s? Right now I calculated at 6k rpms, under full boost, my eaton's demanding ~45hp. One of my concerns is at such time I crank the boost up, am I going to twist the end of the crank off. SC cranks are forged. But then my option of going to 4.2 liters may not be wise. Positive displacement blowers are less forgiving on an engine's rotating assembly because of the little to no lag time that max boost can occure. What are the options of getting a stronger crank?
    Tom
    Dec 2003
    Altoona IA
    3,237
    As far as I know there isn't any options for a crank unless you pay out the nose for a custom crank.
    If you are running a M112 at 6 PSI with a SC crank. Don't worry. There are guys running a M90 at 25 psi and spinning the crXp out of it and the crank is holding up.
    Worry about your harmonic balancer and I've read that the front crank bearing wears a little more than the rest.
    XR7 Dave had almost 200K on his and the last time he dyno'd around 440 HP and 440 TQ.
    Dec 2005
    Wisconsin
    13
    Quote Originally Posted by 90blkbrd View Post
    The Eaton is on my stock splitport 02 Mustang 3.8. Hmmm, I never concidered the harmonic balancer. What effects would happen there? Are the main/rod bearings in the Ford GT made of a stronger material that can handle the extra stress? I read the new Shelby engine is using the same bearings.
    Dec 2003
    Altoona IA
    3,237
    Well then you aren't running a SC crank. They are different than the N/A cranks.
    Aug 2002
    3,660
    Stang man,
    Are you using a SC short block?
    Dec 2005
    Wisconsin
    13
    Quote Originally Posted by Toms-SC View Post
    Stang man,
    No. The engine is a stock 2002 splitport 3.8 v6. The only thing that's not stock, besides the Cobra blower setup, is the GT exhaust and a 25% UDP.
    More info here: http://www.cardomain.com/ride/2452794/3
    NYC
    17,431
    Get a SC lower motor and up the boost..Any type of IC?
    Madison, Ohio
    17,574
    I don't see any reason why that motor wouldn't hold up.
    Email me here.
    Dec 2005
    Wisconsin
    13
    Quote Originally Posted by DamonSlowpokeBaumann View Post
    No innercooling system on it yet. This winter I'll be working on that.
    I've read there maybe problems with breaking harmonic balancers. At what boost output are these situations happening? Has anyone used a billit crank?
    Dec 2003
    Altoona IA
    3,237
    Are you reading about SC balancers or balancers related to your engine? On our cars it isn't power related it's age related. (for the most part)
    I believe there has only been a couple of cranks made for us. No one that I know of has broke a crank due to that engines power levels. David N just ran a mid 10 on a stock crank with a 100 shot of NOS and he pulled 425 on a dyno without NOS.
    NYC
    17,431
    The problem that I have run into with cast or nodular iron cranks with roots type superchargers is that the belt drive puts alot of unsupported weight and extra stress from that weight on the crank snout. You not only get that extra unsupported weight but its also further from the main bearing. If you are running a one belt system that isnt as much of an issue however the drive system running off the crank pulley is either way. I think it be well worth it to look into a SC lower in the future. As has been said the balancer issue is age related.
    I have cracked twisted and bent non steel cranks with roots type blowers
  1. New Magnaport Iii Blower Now Available!
    By victor malvar in forum New Products and Services
    Last Post: 08-25-2005, 06:51 PM
  2. Great Issue in "Engine Masters" magazine about blowers
    By metalman in forum Non Technical Forum
    Last Post: 08-19-2005, 09:13 PM
  3. planning engine buildup. ??IDEAS??
    By kwikcoupe in forum Non Technical Forum
    Last Post: 09-29-2004, 05:39 AM
  4. sc engine swap into mustang
    By matt'sdrag95 in forum Technical Forum
    Last Post: 12-30-2002, 10:12 PM
  5. SC engine swap
    By matt'sdrag95 in forum New SC Owner Forum
    Last Post: 12-30-2002, 01:50 PM
