Results 1 to 11 of 11
Thread: i have a ? about dis
    Oct 2006
    48125,michigan
    4,137
    Thumbs down i have a ? about dis
    92 sc now if i was 2 extend the wires and move the dis 2 the fender lets say would it hurt it more cuz i think it would be better because wouldnt have as much engine heat
    Sep 2003
    P-Town, MN
    2,511
    Quote Originally Posted by 92sclikenew View Post
    I have heard of people doing that. Personally, I would be concerned about the increased resistance due to the splicing.
    It's only impossible until we do it.
    22-year SC owner - '93 SC AOD (non-locking TC). Same car, same original paint!
    Current setup: 12.550 @ 111.09, 1.917 60ft, no bottle.
    Oct 2006
    48125,michigan
    4,137
    Thumbs down
    thats what im asking is it worth it or will it make probs im goin 2 solder it and heat tube it so u think that will still make a prob
    Why not just use ceramic spacers to slightly raise the unit? A small air gap is more then enough to help with temp. I mounted my ignition system and ZEX nitrous system 4" above a transversely mounted exhaust manifold. Only thing between them and the manifold was a thin piece of aluminum and 1/4" ceramic spacers.
    Oct 2004
    Howell, MI
    971
    Quote Originally Posted by CarlisleLandOwn View Post
    I am not sure of the specifics, but i recall some people having some trouble when the DIS warped. Even if only the centor of the module was raised up, it was not functioning properly.
    Oct 2004
    Howell, MI
    971
    I dunno how valid what people say is, but some people in this thread feel that the whole point of the DIS being mounted directly onto a surface is to help conduct heat OUT of the DIS. Apperantly the Convection/Radiation when it isn't mounted directly onto a surface is not enough to keep it in the realm of safe operating temperatures.
    http://www.sccoa.com/forums/showthread.php?t=77004
    20,928
    I wouldn't waste your time.....the stock location works fine.
    Oct 2002
    Covington, WA
    491
    Just get some Arctic Silver from your local electronics shop and that will help a little
    Dec 2002
    Southern Indiana
    358
    i agree, if it works fine in cars up to and over 100k miles, its fine, just be sure to use heat sink compound, NOT dielectric grease!
    '91 5-speed
    My first car, gutted and waiting for resurrection
    '93 5-speed
    289, rebuilt and fuel injected
    Oct 2006
    48125,michigan
    4,137
    how much will heat sink compound cost
    Sep 2003
    P-Town, MN
    2,511
    About $1.99 for enough to do about four applications.
  1. DIS Module Bad Again?
    By Charles G in forum Technical Forum
    Last Post: 12-26-2004, 12:39 PM
  2. We have had two new Dis mudules that were bad in s
    By victor malvar in forum Technical Forum
    Last Post: 12-08-2003, 08:44 PM
  3. No Start DIS???
    By Scott90SC in forum Technical Forum
    Last Post: 10-17-2003, 06:15 PM
  4. DIS problems solved by a rig job.
    By white90sc in forum Technical Forum
    Last Post: 07-09-2002, 02:09 AM
