Results 1 to 15 of 20
Thread: booooooost
    Oct 2006
    48125,michigan
    4,137
    Question booooooost
    how much can the stock motor handle with some open exhast and no raised top like what % pulley could u use and b ok
    20,946
    Quote Originally Posted by 92sclikenew View Post
    5%
    Sep 2002
    Effingham.IL
    5,011
    You can add boost until the boosted air temps get to high
    in the intake manifold. And with proper injector size.
    Mar 2006
    Dayton, OHIO
    142
    10% sc pulley and 38# injectors with ic fan.
    2-3 psi extra boost
    ported blower and plennum gains about 20 hp
    have full open exhaust
    Boost cost Money.
    Jul 2003
    Ottawa, Ohio
    5,401
    I have been running about 20psi for the last 2 years with no problems. Tuning is the key to more boost and power.
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell
    11.676 @ 121.35 mph
    506hp/478tq
    Sep 2004
    Indy
    5,623
    An intercooler is the key to more power with big boost.
    Happy belated Birthday, anyways, dude.
    Jul 2003
    Ottawa, Ohio
    5,401
    Thanks, Cmac
    Forgot the IC thing, exactly why I am ditching the double and going to a FMIC when I put on the MP2 I got
    SCCoA Member#: 2515
    11.676 @ 121.35 mph
    506hp/478tq
    Oct 2006
    48125,michigan
    4,137
    ok so on my car the mufflers are gone and the resonator is knocked out its a 92 sc and has stock pipes and cats what kind of boost upgrades u think i can do
    Mar 2006
    Dayton, OHIO
    142
    How much money do you want to spend?
    Nov 2004
    Brantford, ON
    5,383
    Knocked out the resonator, did you just punch it out, or did you actually remove it and put in a replacement pipe?
    As for boost gains, I still wouldn't go more than 5%. You go 10% without any other mods and you'll lose alot of power because your ACT will be WAY to high.
    Oct 2006
    48125,michigan
    4,137
    knocked it out its still ther and what is ACT
    20,946
    Whatever it takes to make 14 pounds....I'm still thinking about 5%, but you may be able to get away with 10%.
    ACT=Air Charge Temp
    The more boost, the hotter the air will get.
    Oct 2006
    48125,michigan
    4,137
    so your sayin 14 psi of boost is about the max with the setup i have
    Mar 2006
    411
    The big restriction is the exit (Resonator). I would not add much boost until you cut out the resonator or replace it with a free flow type, also the third middle cat if you have one.
    20,946
    I'm saying that I think you will get the most average power out of 14 pounds of boost without any negatives. For example 16 pounds would feel stronger pulling away from a stoplight and spin the tires a little easier, but the additional HP draw from the supercharger and higher air temps, will likely make it slower at high rpms (4500 and up), especially in warm weather. 14 is usually a good balance of bottom end torque and top end HP on a stock motor.
