Results 1 to 7 of 7
Thread: Blower Type?
    Mar 2006
    Dayton, OHIO
    142
    Question Blower Type?
    Does any one know what type of blower I have
    I got 93 sc t-bird man.
    Do I have the M45 or M90 blower..?
    Oct 2004
    Howell, MI
    971
    all SC's came stock from the factory with an M90
    Jul 2003
    South Central Los Angeles
    3,538
    yep, u got the stock m90 with the revised intake plenum!
    Mar 2006
    Dayton, OHIO
    142
    Thanks for the help guys.
    Oct 2002
    Lincoln, NE
    2,062
    Quote Originally Posted by darkstar_one View Post
    There's nothing different about his inlet plenum than one from an '89-'93.
    '94 is when the supercharger was upgraded. That is when the inlet plenum changed slightly (for the better).
    Jul 2003
    3,538
    hmm... what i meant by revised. was the vacuum fittings... they are more easier to work on that the old plenums. im pretty sure i would have said. you got the revised SUPERCHARGER if i meant that! but anywho. i just mentioned the plenum. and was talking about the vacuum fittings...
    yep. i got an extra 94-95 plenum laying around in my garage.... just need an extra 94-95 sc to bolt it onto... manny has my other late model plenum and supercharger case. he should be done with it already..... it smells like fresh tabacco in my room! why! i dont smoke!
    Mar 2006
    Dayton, OHIO
    142
    Quote Originally Posted by 007_SuperCoupe View Post
    I was just thinking of what I had cause specs would not tell me of what I got, well I have increased flow and hp from my blower, I got about 29 hp out of it extra and more flow. I have custumized all my parts and I have not bought nothing extra except repair kits and running 14.1 all stock excapt 10% overdrive pulley and that's all. I got my cooling dony by working with thermostat and air flow to radiator. I have increased from 11 psi stock to ported blower to 11.5 - 12 psi and 10% overdrive I have now 14.8 psi.
  1. Type Of Blower?
    By Toms-SC in forum Non Technical Forum
    Last Post: 11-12-2003, 04:10 PM
  2. stock blower type
    By GONRACIN in forum Technical Forum
    Last Post: 12-28-2002, 08:13 AM
  3. M90 Home Porting and Rebuild Info
    By SeanMatteson in forum Technical Forum
    Last Post: 07-02-2002, 06:32 PM
