Results 1 to 7 of 7
Thread: Water Pump
    Mar 2006
    Dayton, OHIO
    142
    Water Pump
    Does any one know where I can find this water pump?
    Tulsa, OK
    767
    That's a Randy Baker special.
    Oct 2004
    39
    Is that running a electric water pump or an external machanical one?? looks nice and neat.
    Mar 2006
    Dayton, OHIO
    142
    Quote Originally Posted by darnoldrs View Post
    external electric water pump, I got a machine shop working on it of making that for me. and couple more upgrades from stainless steel.
    Sep 2002
    Effingham.IL
    5,011
    Its a aluminum delete plate that replaces the water pump.
    And has stainless steel hoses to connect an external
    electric waterpump motor. made for Gary Khuns.
    The electric waterpump I have has the electric water pump
    motor bolted to the center of delete plate in stock pump location.
    Looks like the stock pump but has electric motor.All radiator
    hoses and hose locations are stock.
    Thanks Randy
    Orem, UT
    5,902
    The actual pump gary kuhn used on the car pictured is a meziere 37 gpm unit. Randy made the plate and it has to fittings that flow from the pump to the plate to circulate the coolant.
    Also it no longer circulates water through the oil cooler or heater core. He also had underdrive pulleys and went to a shorter 53" belt, removed the serpentine tensoiner, and used the alternator to tension the belt by moving it out from the top bracket.
    Here's a post about it but the pics have been removed from the server:
    http://www.sccoa.com/forums/showthread.php?t=30086
    Scott Long
    1992 SC 5-speed
    Sep 2002
    Effingham.IL
    5,011
    I dont think Garys Kuhns designed plate is the best to use.
    When you blow a head gasket,And the pressure leaks out
    through the coolant system. The pressure will blow out the
    radiator seams. There is no expansion room with the use of
    his style set it up.
    Randy
  2. Water pump pulley fell off today...
    By XR7Kurt in forum Super Coupe Club of Florida
    Last Post: 03-25-2006, 06:38 PM
  3. changing water pump
    By alfred in forum Technical Forum
    Last Post: 03-05-2004, 08:20 PM
  4. Stoooopid Damned Water Pump
    By Les Borda in forum Super Coupe Club of Ontario
    Last Post: 08-11-2002, 07:59 PM
