A while back I posted about having difficulty shifting gears in my SC,and was advised that it could be my syncros. Well the clutch pedal went to the floor. After investigating I found that the plastic clip had broke, and the pin that secured the clutch pedal to the slave cylinder actuator had deformed making it impossible for the assembly to work properly.I have searched the boards in regards to clutch pedal removal and my unanswerd question is can I remove the clutch pedal without having to go inside the engine compartment? Also once this is corrected I believe my difficult shifts will be no more. Thanx for the input.
