Results 1 to 5 of 5
Thread: Right Side Motor Mount Bracket
    Aug 2004
    2,031
    I'm looking for a replacement Motor Mount Bracket and Bolt that attaches to the sub frame on the right side (passenger side) for a 1995 SC. The car has a 5 speed whether or not that makes any difference. When I removed the mounts from my car the bolt and bracket stripped out and is unusable.
    UPDATE: I received one off of a 89 and it's not the same part. See attached pic. The mounting holes are about 1/2 inch lower on the 95.
    Ford says any 3.8L 94-97 right side motor mount bracket is the right one.
    Nov 2005
    50
    What year is your car? When I swapped my motor out of my '90 for one out of a '92, the mount on the right hand side was different. The only other difference besides year was one engine came from a manual trans. car and the other was an auto. At any rate, I may still have the lower portion from the '92 w/auto laying around my garage. Let me know if I can help.
    Aug 2004
    2,031
    Oops
    Yup, I forgot to mention the year and tranny info.. See above.
    Aug 2004
    2,031
    Still looking for a right side motor mount bracket for a 95 5 speed.
    Aug 2004
    2,031
    Exclamation 94-97 right side motor mount bracket
    I just found out that any 3.8L 94-97 right side motor mount bracket would work. PLEASE... anybody got one!! It's the one that attaches to the sub frame. In the Ford world, it's part number F4SZ6038C but Ford sells the mount and brackets all as one.
  1. Motor Mount Testimonial
    By MartianBob in forum Technical Forum
    Last Post: 02-23-2006, 12:17 AM
  2. Motor mount change from top
    Last Post: 01-09-2004, 07:19 PM
  3. Low Side AC fitting?
    By Grifter in forum Non Technical Forum
    Last Post: 07-01-2002, 01:31 PM
