Tin-Knocker105
I put under drive crank and water pump pulleys on and now the belt is too long. The tensioner pulley almost hits the water pump pulley.
I know if i put the UD on the alt it would give me a little more room between them, but i'm not using it because i just ordered a new wire harness and higher watt headlights. So i figured it wouldn't be smart to up the wattage of the lights while under driving the alt.
So i need someone to let me know how to figure out the length of the stock belt using the part number K080897 and maybe figure out how much shorter i would need the new belt to be.
Thanks
tony
And before someone says it
I SEARCHED AND ALL THE "short belt" threads were mostly about the SC Belt...
Thanks
tony
