Results 1 to 3 of 3
Thread: Can an Oil Pump be reused
    May 2004
    Stupid Question....If I put a new oil pump on my car M-246. Will I be able to reuse it when it comes time to rebuild another motor.
    Nov 2002
    Palos heights, IL
    Is that the # for the 94-95 pump? You can reuse it but what happends is the timming cover wears and thats where you will gain clearance between the gears and the cover. Maybe just have it resurfaced or replace it when you rebuild. I have reused some pumps but I pick up a rebuild kit for them.
    Lakeville, MN
    There are rebuild kits for the pumps, and if there is over 60k miles on the pump I'd rebuild it. Helps clear up any clearance between the lobes and/or the shafts that has occurred over time. Other than that you should be able to reuse it.
  1. Continued ABS woes (and others)
    By gregs90sc in forum Super Coupe Club of Ontario
    Last Post: 07-11-2007, 08:35 AM
  2. Forgot to Prime Oil pump
    By xtrabolts in forum Technical Forum
    Last Post: 11-09-2006, 10:31 AM
  3. oil pump
    By ZOOMBUGGY3 in forum Technical Forum
    Last Post: 10-26-2003, 04:06 PM
