Results 1 to 8 of 8
Thread: Info
    Feb 2007
    West Palm Beach
    8
    Info
    I recently aquired an m90 from a 93 junkyard supecoupe. I didnt have time to look at what all the hoses were, could someone tell me what lines directly after the tb are for ? Also, there is some play in the pulley, should i have it rebuilt or is that normal?
    Oct 2006
    48125,michigan
    4,186
    Quote Originally Posted by seanyb505 View Post
    the play in the pulley is normal after it has alot of miles but new it wouldn't do that, um i couldn't tell you were all thos fittings hook to but there vacuum lines
    21,122
    PCV valve (includes purge of charcoal canister), main vacuum tree (includes brake booster) and crossover to return plenum.
    Oct 2006
    48125,michigan
    4,186
    wouldn't purge be like blow off valve on on a turbo?
    21,122
    Quote Originally Posted by 92sclikenew View Post
    No...a solenoid valve opens ocassionally and pulls a vacuum on the charcoal canister located in the passenger side front fender to remove gas fumes, from the fuel tank vent.
    Feb 2007
    West Palm Beach
    8
    Thanks for all the info, im looking to find out where exactly the different lines hook up to, like which fitting goes to the brake booster, and if my intake manifold has a brake booster line should i move it to the pre blower spot or can i just plug the pre blower spot?
    21,122
    It doesn't really matter what you hook to each port, but yes you will need to relocate most of the vacuum hoses to the pre-blower side or install check valves if going off the boost side.
    Feb 2007
    West Palm Beach
    8
    Thanks for the info!
  1. Info Display?
    By blitherskite777 in forum Super Coupe Club of Ontario
    Last Post: 05-20-2005, 01:54 AM
  2. "NEED INFO' Calif smog and Kook's Headers?
    By Jim Demmitt Jr in forum Super Coupe Club of Southern California
    Last Post: 04-30-2005, 11:02 PM
  3. Pix and info of trac assist button....
    By CaifanSC in forum Technical Forum
    Last Post: 07-06-2003, 11:18 PM
  4. 2002 MN-12 Nationals Info! UPDATED 3/05/02
    By Boostman23 in forum SCCoA Events
    Last Post: 03-25-2002, 07:48 PM
