Thread: Mark 8 Rear
    Feb 2006
    250
    Mark 8 Rear
    I have a mark 8 rear it is not a trac lock but it is a aluminum housing and has a 3.27 gears in it.
    1. Does this bolt right up in my 90 sc?
    2. does anyone make a locker for this rear?
    thanks for you help
    2,998
    I have an aluminum Mark VIII housing in my 'bird with an Auburn diff and 3.55 gears. In general anything that fits a regular 8.8 fits the Mark VIII housing. You'll just want to get a center section that is made for an IRS since the clips that hold the axles are different from a straight axle 8.8 diff.
    Also, the aluminum cases are a little more difficult to setup for pinion depth and backlash settings. So if you don't know how to set one up, be sure and pay someone who does!
    Aug 2006
    Birmingham, Al.
    319
    Mark VIII = good
    Hi esgtbird. I also built up a mark VIII pumpkin for my '95 auto last fall. I bought an old sc pumpkin off ebay as a donor for the locking diff. The diff gdliii has is one of the best. I've also heard good things about the Torsen. Or, just snatch the locker out of your iron pumpkin. Be sure and put a clutch kit in while it's out. There's a Ford dealer out of GA that sells the kits for about $40 on ebay. If your 90 is a 5-speed. You would be shedding about 12-15 lbs of weight off of the car. And, getting a little more punch from teh lower gear.
    Daspanka
  1. Many Used SC Parts 1989 - 1995
    By sunny627 in forum Parts for Sale
    Last Post: 07-25-2013, 02:07 PM
  2. 94 SC 5 speed and Mark VIII LSC parts FO' SALE!
    By Mercury267 in forum Parts for Sale
    Last Post: 12-18-2007, 01:16 PM
  3. Replies: 3
    Last Post: 05-20-2005, 11:38 AM
  4. mark 8 rear end?
    By Turbong2001 in forum Technical Forum
    Last Post: 09-02-2003, 02:05 PM
