Results 1 to 9 of 9
Thread: Head porting ?
    Aug 2005
    Paoli Indiana
    4,855
    Head porting ?
    Is it necessary to port the exhaust ports on the heads? I started gasket matching mine is it a bad idea? or a help? looks like the ports on the exhaust manifolds are MUCH larger than the ones on the heads so......
    93 SC Red Aod 4.2/2.3lwhipple 422rwhp 11.360
    2013 Shootout Bracket ET First Place
    2015 Shootout Car Show Honerable Mention
    2016 Shootout Mod-1 First Place
    2018 Shootout Pro Street Runner Up
    Coming soon new motor 2300 TVS etc..
    90 35th aod stock, 90 5 speed Bolton Build in progress
    Apr 2005
    Nor Cal
    2,985
    There is supposed to be a lip on the Head exhaust ports to prevent exhaust gasses from feeding back into the heads. But as far as porting, im not really sure.
    - Dan
    Aug 2005
    Paoli Indiana
    4,855
    So leave the lip?????
    Aug 2005
    Paoli Indiana
    4,855
    Does anyone know if this lip should be left????
    Jul 2003
    Ottawa, Ohio
    5,436
    do not port match the exhaust side just smooth and polish it up. do a search there are tons of threads on head porting. This is also an informative link
    http://www.sa-motorsports.com/do-it-yourself.aspx
    SCCoA Member#: 2515
    1990 SC AOD 2.1L Kenne Bell
    11.676 @ 121.35 mph
    506hp/478tq
    Apr 2005
    230
    heads
    what if i took the lip off and gasket matched it? would this be a huge problem? don
    Jan 2007
    132
    A lip can be good for anti-reversion. If you are staying with stock manifold, I would leave the port size alone and concentrate your efforts on making them smooth and straight. The problem is the firing order and reversion is a problem on most manifold designs. Longer primaries will help but unless you are going to build your own bundle-of-snakes 6-3-1 (1&5 2&6 3&4, each primary 180' out) exhaust, reversion is a concern.
    Also, the further you port the stock exhaust manifold primaries, the further you can open up the exhaust port and still have the same degree on anti-reversion.
    Jason
    Apr 2005
    230
    porting
    well i already ported it to match, so ill have to see if it helps or not. ill let you know once the car is together and running. don
    Apr 2004
    sumter, south carolina
    3,050
    here's a good head porting thread for u members :
    http://www.sccoa.com/forums/showthre...orting+exhaust
  1. Head Porting
    By Kingghost in forum Super Coupe Club of Ontario
    Last Post: 07-11-2005, 10:30 AM
  2. I want to make a head porting video...
    Last Post: 06-24-2005, 02:13 AM
  3. 90% rule for head porting....
    By CMac89 in forum Technical Forum
    Last Post: 02-28-2005, 01:46 PM
  4. Head Porting -- In SE lower Michigan?
    By 91BLOWNSC in forum Technical Forum
    Last Post: 06-27-2004, 12:37 AM
  5. Porting head...have a question (pics)
    Last Post: 12-19-2003, 09:43 PM
