Results 1 to 6 of 6
Thread: Koni Yellow Inserts
    Aug 2002
    3,669
    Koni Yellow Inserts
    Hey,
    Is there any better directions then the ~~~~ that is included with them from the factory? Any tips to installing them? Thanks
    Sep 2006
    HARRINGTON DE
    1,193
    I don't think there is any better instructions at least I didn't find any when I was looking for some.I just did mine about a week ago and I put a hose clamp around the strut to use as a guideline.I put it a little below where the strut tapers to the full size then used a cut-off wheel to make the cut.Once I had it cut I used a file and some sandpaper to dress the cut.Then remove the shaft and inner valve assembly and drain and clean up the inside with some brake cleaner.Then just use a center puch to give you a place to drill you're bottom hole and drill it to size.And you're done it only took me 20 or 30minutes to modify both sides.
    Jay
    Tulsa, OK
    767
    You might search on TCCOA. Here's one, but all the pictures are gone.
    http://www.markviii.org/dcforum/DCForumID13/1861.html
    Aug 2002
    Toronto
    1,745
    I did mine last summer,i used a recipricating saw to cut the stock shock.It is a cleaner job and leaves less rough edges.
    Aug 2002
    3,669
    Quote Originally Posted by cougarsc View Post
    Damn! I'll do some digging there.
    Jan 2007
    132
    Not sure if its good or not to be able to get almost anything ever posted on the internet... but here it is...
    http://web.archive.org/web/200410190...ID13/1861.html
    Jason
  1. Black Leather Door inserts and Speaker covers
    By getblown in forum Want to Buy
    Last Post: 01-18-2005, 12:24 AM
  2. Koni strut install and problem
    By justin07 in forum Technical Forum
    Last Post: 05-06-2004, 11:19 AM
  3. Free Stainless Steel Rear Inserts
    By bbaarrrryy in forum New SC Owner Forum
    Last Post: 11-03-2003, 08:23 PM
  4. Impreza WRX, yellow, yellow, yellow, green! winner?
    By GREATWHITE666 in forum Non Technical Forum
    Last Post: 09-24-2002, 02:44 AM
