Thread: 5-speed aluminum driveshaft question
    Feb 2003
    Tinton Falls, NJ
    1,664
    This is actually for my 91 cougar that I'm putting a 393 in, not my 89 XR7, but anyway, here is the situation.
    I am putting the M5R2 trans in this car. I am also moving the engine back by 1 inch. I want to put an aluminum driveshaft in the car, but no one makes one that is 52.5" long. I was thinking about buying one out of a crown vic cop car and having it shortened to the right length, but I don't know if that driveshaft uses the same U-joints as the SC shaft. Can anyone help me out here as to what driveshaft I could use and have shortened? Or if there isn't one, the guy at the driveshaft shop said he could make me one for $400, but shortening an existing shaft is only $100, so I would prefer to find something to start with if it exists. Thanks.
    Mike
    Apr 2005
    Nor Cal
    2,985
    Hmm, im not completely sure .. but I know the AOD and 4r70w / AODE have a different yoke and U joint. So if the m5r2 uses the same yoke as the AOD, it wont interchange with one from the Crown Vic if it has the AODE ...
    - Dan
    Jan 2006
    Shreveport, LA
    413
    You should sign as there is a members only FAQ pertaining to the swap...
    Three meals at McDonalds...or questions like these answered...
  1. I found this FAQ on the SC
  2. Aluminum Driveshaft 1994-1995 SC (4R70W)
    By Rich Thomson in forum Parts for Sale
    Last Post: 10-05-2004, 11:46 AM
  3. Low Speed Fan Question....
    By pepito6SC in forum Technical Forum
    Last Post: 07-23-2002, 07:13 PM
  4. Rear end question...speed sensor?
    By ChaseTruck754 in forum Technical Forum
    Last Post: 06-25-2002, 02:04 AM
