E3 Sensor location
Hi guys, I am reviewing the E3 problem in my car. I checked the EVT and there is a sensor next to the JBL stereo. Is that the sensor that I have to replace?
I checked the other forums ( fordforums) and found the following info:
The Cabin Sensor is located above the air con register behind th instrument panel and contains a thermistor that measures cabin temperature. It's easy to find as its at the end of the duct that the sniffer motor (small fan) takes air from the the small dash vent to the left of the heater demister switch. Check vent isn't blocked, sniffer motor has failed or wires disconnected from sniffer motor or sensor. If not working the climate control will misread the cabin temperature and you wont get effective hearting or cooling.
Basically what it is saying is that if the Cabin Temperature sensor doesnt work, then the Blend Door Motor (The Temperature Door), will be somewhat out of whack, as the Climate control module will assume that the cabin temperautre is always 21*C
Also, it will effect the Coolant Thermal Control Valve, which will allow Coolant to flow to the heater, if Heating is required (This Tap will always be open !)
(I.E. on a very hot day, the CC will think that the Cabin temp is nice and cool, and doesnt require very much cooling - EG, Cabin temp may be 40*C, and you have the climate control set to 22*C, with the Cabin Temp Sniffer motor stuffed, the Climate Control Module will HEAT the air temp, rather than cool it.....)
On the EA-ED models, the Cabin Sniffer Motor is located behind the Climate Control Module, so you will need to take that out.
It is also towards the Trip Computer part.
Basically it looks like a small coke can, and has 1 wiring loom coming from it, that goes directly to the Climate Control Module.
(On the climate control module, there are 3 connectors (EA-ED), the connector that is Horizontal, (Not the 2 Vertical ones), is the connector for the Cabin Temp Sniffer Motor.
Finally, there will be a Plastic hose coming from the Sniffer motor, going to the Venty thing, next to the Power Antenna, and Demister Switches.... This is the hose that sucks air in to see what the Cabin temp is......
Most prolly your problem is a connector is loose....
Worst case, the Cabin temp sniffer motor has carked itself, and will need to be replaced.
